![]() | Home > Technical (L322) > Sketch round left hand bends....... |
| Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640
I had a similar issue with mine where the rear left strut was busted.
| Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 226
did they change the upper and lower hub bushes, mine is getting a bit loose in the rear end. |
| Markwood71 Member Since: 19 Sep 2019 Location: Dudley Posts: 31
when they changed the lower arms- we looked at the shocks etc, so see if they needed swapping while the car was on the ramp= and they were not weeping , and can't say I've noticed any unusual bounce- but i'll be on the look out now. Welcome Rosie J - The Newer Kid on the Block
they changed the complete lower arm- and i was told the upper arms etc were fine- so no. Welcome Rosie J - The Newer Kid on the Block RIP Rosie (We all Love Rosie - especially in S mode at the traffic lights) |
Just another thought… check that all bolts are tight in case one was missed?
Assuming they changed the lower, there is an upper thats wears quite easily. Do you get any squeaking in dry weather? plus 1 on checking the bolts |
no squeaks- , but will ask them to double check the upper carrier and bushings when its on the ramp later this week. Welcome Rosie J - The Newer Kid on the Block
| Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 714
I'd definitely be checking for loose hub bolts & nuts. Paul,
| Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 342
Rear suspension sensors on the top of the shock? They are all wearing out on the 2010-2012 models now and may be giving bad info back.
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3399
Had a front one changed but didn't show on a GAP IID scan. 2012 TDV8 Vogue (L322) |
| Treebor99 Member Since: 07 Feb 2021 Location: Rugby Posts: 34
I'm sure you've probably checked tyre pressures more than once - but I didn't see it mentioned.
Possible i guess. would have though that would have left the car unbalanced whiles sitting though- but i can check. Welcome Rosie J - The Newer Kid on the Block RIP Rosie (We all Love Rosie - especially in S mode at the traffic lights) |
Yeah- check tyre pressure often as i'm a bit OC with them ( saves money !!) I am thinking it might be the shock as it feels like its giving way almost when turning. I'll get them to check all the nuts and bolts however as hopefully it will be an easier fix for the wallet. Welcome Rosie J - The Newer Kid on the Block RIP Rosie (We all Love Rosie - especially in S mode at the traffic lights) |
| All times are GMT |
