Home > Technical (L322) > Sketch round left hand bends.......
Markwood71
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
Strange one, with a bit of back story. When i take a left hand bend , the back right steps out ( or wants to) and the traction control lights up. Right hand bends- all fine and dandy. When i say steps out- i mean at 30mph, it feels like the back is on ice.
List of recent work as below_
new rear discs & pads
rear lower arms- both sides. new & complete.
4 new tyres
4 wheel tracking
2 x new front air struts complete
all 4 corners calibrated to correct height using IID tool
anyone want to try and shed some light on this? Question Welcome Rosie J - The Newer Kid on the Block
RIP Rosie (We all Love Rosie - especially in S mode at the traffic lights)
Post #609711 19th Oct 2021 2:19pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I had a similar issue with mine where the rear left strut was busted.
However for me, it was with any uneven surfaces such as drain covers or poor road surfaces.
In addition, if I hit any speed humps the rear left would bounce more than the right.
Maybe something to check? Does the back of the car bounce more than the front? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #609717 19th Oct 2021 3:05pm
Snowy90 L322
United Kingdom 2019 Range Rover Vogue SDV6 Baltic Blue
did they change the upper and lower hub bushes, mine is getting a bit loose in the rear end.
Post #609718 19th Oct 2021 3:21pm
Markwood71
when they changed the lower arms- we looked at the shocks etc, so see if they needed swapping while the car was on the ramp= and they were not weeping , and can't say I've noticed any unusual bounce- but i'll be on the look out now. Welcome Rosie J - The Newer Kid on the Block
Post #609720 19th Oct 2021 3:27pm
Markwood71
they changed the complete lower arm- and i was told the upper arms etc were fine- so no. Welcome Rosie J - The Newer Kid on the Block
Post #609721 19th Oct 2021 3:30pm
Ffrr-lover
Just another thought… check that all bolts are tight in case one was missed?
The same goes with the wheel itself… I’ve heard a few horror stories about loose bolts on wheels Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #609722 19th Oct 2021 3:30pm
Snowy90 L322
Assuming they changed the lower, there is an upper thats wears quite easily.
Do you get any squeaking in dry weather?
plus 1 on checking the bolts
Post #609723 19th Oct 2021 3:35pm
Markwood71
no squeaks- , but will ask them to double check the upper carrier and bushings when its on the ramp later this week. Welcome Rosie J - The Newer Kid on the Block
Post #609726 19th Oct 2021 3:59pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
I'd definitely be checking for loose hub bolts & nuts. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #609736 19th Oct 2021 6:01pm
Range Rover L322
Rear suspension sensors on the top of the shock? They are all wearing out on the 2010-2012 models now and may be giving bad info back.
Not expensive and easy to change so I suggest doing them anyway to eliminate it as a possible issue.
Post #609748 19th Oct 2021 8:03pm
JayGee
Had a front one changed but didn't show on a GAP IID scan. 2012 TDV8 Vogue (L322)
Post #609764 20th Oct 2021 6:56am
Treebor99
United Kingdom 2011 Range Rover Vogue TDV8 Fuji White
I'm sure you've probably checked tyre pressures more than once - but I didn't see it mentioned.
Under inflated lets the tyre squirm about giving the sensation you describe.
Over inflated has reduced contact patch giving the sensation you describe.
Otherwise as previous posts, something suspension or damper related.
hope you get to the bottom of it - it doesn't inspire confident driving when the back is sliding. Anything can be made to work if you fiddle with it long enough (and have deep pockets|)
Current cars, 2011 FF 4.4 TVD8; Audit TT 1.8T convertible.
Post #609850 20th Oct 2021 3:18pm
Markwood71
Possible i guess. would have though that would have left the car unbalanced whiles sitting though- but i can check. Welcome Rosie J - The Newer Kid on the Block
Post #609851 20th Oct 2021 3:29pm
Markwood71
Yeah- check tyre pressure often as i'm a bit OC with them ( saves money !!) I am thinking it might be the shock as it feels like its giving way almost when turning. I'll get them to check all the nuts and bolts however as hopefully it will be an easier fix for the wallet. Welcome Rosie J - The Newer Kid on the Block
Post #609855 20th Oct 2021 3:31pm
