Home > Maintenance & Mods (L405) > Car finally delivered!! - Which C-Tek Charger for a 5.0 S/C
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
So, I finally got my new L405 5.0 SC AB LWB last week (see below).
I'm really happy with the car but won't be using it all the time, as I have the L322 for local daily driving with the dogs.
Please can anyone tell me which C-TEK trickle charger I need, which sort of connector is required, and how I connect it to the car?
I've tried looking on YouTube but can't find a "How To Guide" anyone know different?
Many thanks in advance
Post #614911 5th Dec 2021 8:19pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Very nice looking Thumbs Up Thumbs Up
Post #614930 5th Dec 2021 10:34pm
aja500
Thanks DrF Thumbs Up Thumbs Up
Post #614935 5th Dec 2021 10:51pm
mjdronfield
I think if you just want to maintain a good battery any of them will do.
If you want to fully charge from totally flat, the bigger chargers will do it faster. Smaller ones might not do it at all.
I have an MXS 7 and it’s done everything I’ve needed. That’s a 7amp charger… hence the number. The 10 will charge faster but costs more.
They were on offer last week with Amazon.
I use the towing electrics to charge, using an adapter from the site shop.
If you don’t have towing electrics, you can connect a comfort connector to the battery permanently and just plug in to that from your charger.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #614940 5th Dec 2021 11:17pm
aja500
Thanks MJDronfield
It's not charging from flat, just maintaining a new battery.
I have a spare one of these, albeit about 5 years old, although it was only ever used for about 6 months.
Would this work on the battery for a L405 5.0 SC?
https://www.amazon.co.uk/CTEK-MXS-5-0-Reco...5&th=1
I'm guessing this is the comfort connector - Are these easy to fit?
https://www.halfords.com/motoring/battery-...mp;_=tsid:|cid:13230549599|agid:129538708744|tid:pla-875537407562|crid:523555172092|nw:u|rnd:10990889045391740859|dvc:c|adp:|mt:|loc:1006781&gclid=EAIaIQobChMIkcTzjdrN9AIV_IBQBh3AuQi8EAQYASABEgKIF_D_BwE
Post #614941 5th Dec 2021 11:25pm
pld118
The MXS 5.0 charges batteries from 1.2-110Ah. Does the 5.0 not use a 110Ah battery? I’ve got one and have used it with ease to charge/ condition the 4.4TDV8, the 3.0TDv6, smaller diesel and petrol engines.
Post #614943 5th Dec 2021 11:52pm
mjdronfield
That should be fine for maintaining it. You might get one of those connectors with the charger. They just bolt to the battery terminals. I’ve no experience with the L405 though, I think the battery is in the boot now? Those with 405s will be better placed to advise on where to connect and cable routing etc…
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #614944 5th Dec 2021 11:55pm
pld118
I think the 5.0 petrol is between 80 and 110Ah… you can either look at your battery or put your reg. number in the ECP website and it’ll tell you what size battery, as two ways of confirming/ finding out…
Post #614946 6th Dec 2021 12:05am
aja500
Thanks Pld118 and MJ Dronfield.
Entering the vehicle type into ECP website suggests a few alternative batteries from 75 - 90ah, so all below 110ah, which I guess is the main thing.
Yes, MJD, I think you might be right about the connector, I'll check in the box. I also think you might be right, and the battery may be in the boot on the later L405 / 5.0.
There is also a second Auxilary Battery (14ah) coming up on the EPC website, so not sure if it has two batteries now?
The crazy thing is, you no longer get an owners manual with a new L405, apparently JLR say it's for paper saving reasons!!!
They told me there's an APP I can look at, but I've always liked a manual to refer to.
Post #614947 6th Dec 2021 12:23am
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
I use the CTEK 5.0 and it works just fine on my AB V8 S/C. The auto stop/start even works!
Post #615009 6th Dec 2021 12:26pm
knwatkins
I also have a CTEK MXS 5.0 and it does a good job of maintenance charging. I just connect it up to the terminals under the bonnet whenever I'm not going to be using the car for a few days. That's on my SDV8 which has a 95Ah/850A CCA main battery plus a 70Ah/760A CCA auxilliary battery. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #615063 6th Dec 2021 4:28pm
knwatkins
The battery is in the boot, under the air compressor, on all L405s Thumbs Up Kev
Post #615068 6th Dec 2021 4:47pm
aja500
Thank you all for your help and comments - The MXS 5.0 it is then, saves me buying another Thumbs Up Thumbs Up
Post #615081 6th Dec 2021 5:52pm
Do you have the deployable tow bar? If so then I'd second MJDronfield and advise using that with a connector from the site shop and the CTEK 5. That's what I do and it works well. Advantages include: not having to get at the battery or terminals which are quite well hidden away; regularly exercising the tow bar mechanism which is liable to stick if ignored for months/years on end; and all cabling external to the car so no seal strip deformation. Mike - MPx
Post #615100 6th Dec 2021 9:03pm
aja500
Thank you for your reply MPx - I didn't spec the tow bar, so unfortunately can't use that method.
I think it should be quite straightforward from what I understand. If I can fix the CTEK comfort cable to the battery terminals underneath the rear loadspace area, and add an extension cable if necessary, this should leave an easy access charging point in place.
Battery location I believe to be here:
Post #615125 7th Dec 2021 8:48am
