Home > Maintenance & Mods (L405) > Car finally delivered!! - Which C-Tek Charger for a 5.0 S/C |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1260 |
Very nice looking |
5th Dec 2021 10:34pm |
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 816 |
Thanks DrF |
5th Dec 2021 10:51pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7638 |
I think if you just want to maintain a good battery any of them will do.
5th Dec 2021 11:17pm |
Thanks MJDronfield
5th Dec 2021 11:25pm |
The MXS 5.0 charges batteries from 1.2-110Ah. Does the 5.0 not use a 110Ah battery? I’ve got one and have used it with ease to charge/ condition the 4.4TDV8, the 3.0TDv6, smaller diesel and petrol engines. |
5th Dec 2021 11:52pm |
That should be fine for maintaining it. You might get one of those connectors with the charger. They just bolt to the battery terminals. I’ve no experience with the L405 though, I think the battery is in the boot now? Those with 405s will be better placed to advise on where to connect and cable routing etc…
5th Dec 2021 11:55pm |
I think the 5.0 petrol is between 80 and 110Ah… you can either look at your battery or put your reg. number in the ECP website and it’ll tell you what size battery, as two ways of confirming/ finding out… |
6th Dec 2021 12:05am |
Thanks Pld118 and MJ Dronfield.
6th Dec 2021 12:23am |
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 147 |
I use the CTEK 5.0 and it works just fine on my AB V8 S/C. The auto stop/start even works! |
6th Dec 2021 12:26pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 735 |
I also have a CTEK MXS 5.0 and it does a good job of maintenance charging. I just connect it up to the terminals under the bonnet whenever I'm not going to be using the car for a few days. That's on my SDV8 which has a 95Ah/850A CCA main battery plus a 70Ah/760A CCA auxilliary battery. Kev
6th Dec 2021 4:28pm |
The battery is in the boot, under the air compressor, on all L405s Kev 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
6th Dec 2021 4:47pm |
Thank you all for your help and comments - The MXS 5.0 it is then, saves me buying another |
6th Dec 2021 5:52pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 527 |
Do you have the deployable tow bar? If so then I'd second MJDronfield and advise using that with a connector from the site shop and the CTEK 5. That's what I do and it works well. Advantages include: not having to get at the battery or terminals which are quite well hidden away; regularly exercising the tow bar mechanism which is liable to stick if ignored for months/years on end; and all cabling external to the car so no seal strip deformation. Mike - MPx
6th Dec 2021 9:03pm |
Thank you for your reply MPx - I didn't spec the tow bar, so unfortunately can't use that method.
7th Dec 2021 8:48am |
