Home > In Car Electronics (L322) > Ignition won’t turn off, help!
Deputy
United Kingdom 2008 Range Rover Vogue TDV8 Barolo Black
Dropped down to the shops, tried t turn the ignition off but key won’t turn! The engine is left running now outside my house what can I try? Help! L322 tdv8 2007
Post #617686 27th Dec 2021 2:27pm
Disconnecting the battery -ve terminal should do it, it will disable the fuel solenoid and cut off fuel to the engine.
Post #617690 27th Dec 2021 2:47pm
Deputy
Didn’t work. Engine still running.
Post #617696 27th Dec 2021 3:07pm
Deputy
Tried pulling fuse 18 to see if it resets ignition switch, no good.
Post #617699 27th Dec 2021 3:17pm
kevinp
Is it just idling or revving?
Post #617701 27th Dec 2021 3:26pm
Deputy
Idling.
Post #617702 27th Dec 2021 3:29pm
kevinp
Is there any smoke from the exhaust? Could be running on engine oil from a leaking turbo.
Post #617703 27th Dec 2021 3:31pm
kevinp
You need to block the air inlets somehow to starve it of air.
Post #617704 27th Dec 2021 3:35pm
Deputy
No. It’s the ignition barrel. The key won’t turn anti-clockwise to switch the ignition off. It’s stuck somehow.
Post #617705 27th Dec 2021 3:38pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Fuse 25, 31 or 39
Post #617706 27th Dec 2021 3:45pm
Weegie
or fuel pump relay in rear fuse box? Pulling fuse or relay won't be instant. Need to clear fuel in the lines and filter. John
GAP iiD BT-Sold
Post #617707 27th Dec 2021 3:51pm
Deputy
Pulled 31 and that’s stopped the engine. Phew!!
Wondering what to do next. Plenty of advice here on ignition not starting, not much on ignition not switching off.
Post #617708 27th Dec 2021 3:53pm
Deputy
Replaced the -ve battery terminal to try and start up.
Dash lights came on but key won’t turn in barrel. Disconnected battery for now.
Can’t be the immobiliser if key still stuck in II position can it?
Post #617709 27th Dec 2021 4:01pm
tb10
Swap fuse 18 or check it’s clean. Mine had a similar issue and the fuse I used was not making a good contact. Glad fuse 31 worked Shocked
Post #617716 27th Dec 2021 4:41pm
tb10
Is yours a key in dash or key down by the handbrake?
Post #617719 27th Dec 2021 4:46pm
