Home > Maintenance & Mods (L322) > What to do if your DPF is blocked...
Page 32 of 43 <123 ... 313233 ... 414243>
Corsica
France 2011 Range Rover HSE TDV8 Santorini Black
Post #615197 7th Dec 2021 5:08pm
Range Rover L322
Nice video.
Of the fields you have I have found the following ones are not always reliable and may be misleading.
Incomplete Regen Status
Number of partial successful regens
Number of successful regens
the rest is great but it is best to rely on the Demanded Regens field which always works and couple it with some heat sensors so you can see the regen happening.
Post #615235 7th Dec 2021 10:00pm
Corsica
Agree with you, find someone who could make a complete demonstration about it🧞‍♂️
Post #615252 8th Dec 2021 8:01am
AndesinWales
Wales 2012 Range Rover Autobiography 4.4 V8 Santorini Black
Only a few months into ffrr ownership, but read this thread with interest. I have a Kubota tractor and that has a display telling me what percentage full the DPF is at any time. I wonder why this isn’t a system generated message on the dash? Or is that what the DPF full message replicates. If that was set to a percentage, like my tractor, managing the regeneration process would be a lot easier.
Post #616607 16th Dec 2021 12:12pm
Range Rover L322
Re: the percentage on the dash, absolutely agreed.
The DPF full warning signs serve to simplify it:
19.6g Regen Demanded
23.3g Amber Warning On
27.5g Red Warning On
So "Working", "Needs a Fast Run", "Broken".
Some of the reasons for not having a more comprehensive readout, as I understand it are the DPF fill rate is extremely variable from car to car and it was a bit of a dirty fix at the time when DPF technology was all new. Also the fill rate on each specific car is inconsistent which is going to bother people if they know too much... It works well in most cars, no reason to bother people with it...
Having been tied in knots myself by well intentioned but ultimately misleading advice, I can honestly say I reckon the design is a good one for a top end car... especially one with such variation in performance!
Post #616781 17th Dec 2021 11:18pm
AndesinWales
DPF Soot fill rate
Fairly new to RR (2012 L322 4.4 TDV8 with 51k miles) and GAP IID tool. Had Exhaust Gas Temperature Sensor replaced a few weeks back. Started to view and monitor soot levels and this is what I’ve seen
Pre Xmas soot level was reading 15g. Took it out for a run yesterday afternoon. Mix of dual carriageways and B roads. Covered about 80m. When I got home plugged in IID and soot levels read 17.7g. Never had a yellow light, but thought it best to give it another run to see if it would regen. Left IID plugged in and set off.
7 miles of B roads and 26 of dual carriageways at 50 mph +. Watched soot reading increase to 20g. Thought it would go into regen before that, but shortly after, soot levels started to decline down to 10.2g when I ran out of dual carriageway and joined M4. Had hoped regen would continue, but it stopped. Drove for another 27 miles to get back home. On arrival soot levels had risen to 13.2. Soot levels seem to be rising at a rate of about 0.09g average per mile on my last run.
I suspect my joining M4 at roundabout and having to stop fooled the ECU that regen was over, although others on this thread have suggested regen can continue in similar circumstances. Just before the low of 10.2g, the reduction rate had slowed considerably. I’ll do another run when soot reading is higher.
Questions - why might it have taken a soot reading of 20g to begin regen given my 50+ speed? - do those in the know think my soot levels after regen are rising too quickly?
0g to 20g at a rate of 0.09g per mile would suggest a regen range of around 223miles. I read from the earlier workshop manual post that there was a mileage backstop in the ECU of 250.
Car drives lovely, never had yellow regen light. Maybe it is what it is!
Post #617898 29th Dec 2021 2:25pm
DrRob
Unplug your IID and don't monitor it. Its working OK and you'll drive yourself nuts watching soot levels. No warning lights = Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #617927 29th Dec 2021 6:41pm
JohnW
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
Red DPF Triangle
Interesting reading on DPF's.
Where and what version of IID should I buy to monitor and check? I have looked online under IID or OBD2 and loads of versions nothing saying about soot monitoring.
I have only had my RR since April ( 2011 TDV8 4.4 Autobiography ) and love it but sadly kept putting of a motor way drive when the yellow DPF light came up and now I have the red one. My local garage tried to reset it twice and told me to go for a drive and see if it made a difference but still limp mode, can still get to 70 but can make a cuppa whilst it takes its time getting there.
I feel I may have to bite the bullet and go to the dealer as I have now suffered for 3 weeks with this and need it sorted so hoping that Peterborough Dealers aren't to expensive to reset / clean the filters and not my wallet!! Unless anyone knows another local garage I could go to that would do this?
Yet another excuse for my wife to say why we should stick to her ford Bmax 1.6 Diesel instead of the much safer more comfortable luxurious RR. Really hope I cant get this sorted without to much expenditure.
[img]
[/img] 2011 4.4TDV8
Autobiography
2007 Freelander 2
2003 Audi A6 2.5TD
Post #617952 29th Dec 2021 11:13pm
Range Rover L322
AndesinWales, ... I completely agree with Dr Rob. There's such variation in these cars as well as soot fluctuation.
I have been watching mine for 2.5 years and 8000 miles and have only just got it completely sorted.
If you don't have a yellow it's not worth looking for a problem.
All the best and Happy New Year.
Post #617953 29th Dec 2021 11:15pm
Range Rover L322
Hi John W.,
I use an IIDTool with Bluetooth, as do most people on here. Getting into that is an investment in both money and time to understand it.
As soon as you get a Yellow DPF Warning you should really go for a drive at faster than 37mph for approx 15 mins+
If your local garage resetting the Red DPF warning did not get you out of limp it suggests there may be a bigger issue (dont worry mostly not too expensive!).
If there is a bigger issue somewhere, the DPF is the receptacle, but not the cause (DPFs are very rarely faulty). Your car is most likely producing too much soot and effectively overloading the DPF - it is probably a leak somewhere in your induction system, or possibly just a MAF/MAP sensor sooted up. Induction Leaks account for most of the issues, next is because the car is used for very short journeys, after that we get a few peculiar things like sensor or turbo issues and it all gets a bit fruity.
A high pressure smoke test is the starting point to find the leak. This should be your local garages next move if the Red reset does not work. I recommend finding a garage who knows the score, it is a bit specialised for a lot of them.
Good luck and keep us updated. You will get sorted.
Post #617960 29th Dec 2021 11:38pm
johnboyairey
Re: Red DPF Triangle
[img]
[/img]
bought mine with the yellow warning showing, test drove it, shook hands, paid for it, went to fill it up, and red light came on, 'go to dealer' etc. so knowing I had a 100 mile trip on the m40 to get it home, I did drive it around for about 10 miles first,, but considered a motorway blast... trouble was, it wouldn't blast at all. it would slowly reach about 50mph, and hardly any faster.... but I soldiered on, steady she goes, behind a truck for about 50 miles... I tried a few command shift downshifts to raise the revs, but that 'times out' at about 1 minute, and you drop back to 'D' however, I wanted to check the car at a services, and after a coffee and a break, I was relieved to see it had gone out, and full power restored! car was transformed, and drive home was fine, done about 600 miles since, and no return of either red or yellow etc. (car has mileage of 197k! )
Post #617961 29th Dec 2021 11:39pm
Range Rover L322
johnboyairey,
That's great you cleared it.
Quick tip - if you pop it in Sport "S" it will stick in whichever gear you want for as long as you want.
Post #617962 29th Dec 2021 11:46pm
johnboyairey
I wondered that... had a lot to think about on that long limp journey, and didn't want to tempt fate! didn't even have the radio on, in case I didn't hear a 'noise'!
Post #617964 29th Dec 2021 11:59pm
JohnW
Range Rover L322 wrote:
If your local garage resetting the Red DPF warning did not get you out of limp it suggests there may be a bigger issue (dont worry mostly not too expensive!). because the car is used for very short journeys, after that we get a few peculiar things like sensor or turbo issues and it all gets a bit fruity.
Don't think my garage is that advanced so will look around this week to see what I can find. I presume that I am not damaging the engine by driving around without turbos working? (So frustrating having micra's overtaking you on parkways!!! lol) 2011 4.4TDV8
Autobiography
2007 Freelander 2
2003 Audi A6 2.5TD
Post #617975 30th Dec 2021 1:08am
DrRob
Quick google maps search throws up Avenger 4x4 as the first place I’d go to round Peterborough
Avoid all main dealers unless you like being reamed Shocked
As above, it’s highly likely to be an induction leak e.g. the 4 inlet donut hoses can split. Replace with silicone etc. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #617994 30th Dec 2021 9:54am
