![]() | Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Unfortunately the air suspension in our cars hides issues with the struts themselves.
I think they all need re-adjusting over time. Mine was out when i got the car so I corrected it… but it didn’t improve the ride for me.
My rear strut had totally gone, but the car was level and ok to drive… except on the imperfections. My car rocked over bumps and speed humps, and those imperfections caused the rear to be unstable. The rear would kick out if you hit those imperfections on a bend. If you are getting a bouncy ride, then it could be knackered struts… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
For me, it was obvious when going over speed humps. The rear left bounced more than the right.
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
I have rear l322 cvd dampers in the for sale section if anyone is after a set. Bilsteins 1995 4.6 v8, green/tan (long gone)
LandyManSam Member Since: 10 Jul 2019 Location: Wild West Ireland Posts: 51 ![]() ![]() ![]() |
So I'm re-awakening this thread to post my progress on this issue as well as hopefully get more input from you guys...
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
I’m no expert on this by any means, but if both front struts are too hard, I would imagine it’s pretty unlikely they would fail at the same time in the same way? So they must both be getting a signal making them so…. As I say…. Just using logic…. If you go round a right hand bend just the left ones should firm up… I would imagine…. Can you feel any change from cornering to not cornering? If you brake hard does the front dip loads? Is it still level?….
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3345 ![]() ![]() ![]() |
Mine rides so much better on new tyres (7 years old vs new Verde's) 2012 TDV8 Vogue (L322) |
It feels firm all-around, not specifically in the front or rear really. True that they're less likely to have both failed, but if one is dodgy I guess it's plausible that it would negatively impact the performance of the other? During cornering yes the dampers are supposed to try and counteract body roll. It doesn't roll excessively for what it is, but difficult to determine whether there's any change in ride. I don't think so as bumps are still painfully felt during corners. Front dips quite a bit during braking but doesn't feel like an inappropriate amount for a big 4x4 really, but haven't got another one to compare it to. |
Mine is on 9 month old Cooper AT3s which are only about 10% worn. Some people have said that non-standard tyre fitment could cause the VDS to do funny stuff, but I'd point out that I had the same issue prior to changing tyres when it was on its original 19" rims and 255/55 R19s. |
I don’t think communication to the dampers is 2 way…. What’s your thinking on how a faulty one might affect the other? Extra body roll causing sensors to then try and harden dampers more?
I meant more that if one damper is acting up / not working as it should be, then it would affect the attitude of the whole vehicle as opposed to just the one corner - it's not always easy to pinpoint which corner is the problem, especially on an electronically suspended and damped vehicle like this.
Oddly enough i was thinking about this the other day with the intention of asking how you were getting on, either here or your YouTube channel (love it btw)…
By God, you will know if it’s not working, suspension goes rock solid. Made me feel sick driving on a relatively smooth dual carriageway…. When I had strut wiring break and Adaptive Dynamics Fault on dash.
Feel more road undulations…
