![]() | Home > Maintenance & Mods (L322) > Front and Rear Differential Change… How? |
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
One thing David be careful with the wheel bearings I did mine and am about to replace front offside hub as the bearing is moving in the case I had to do one of the rears as well - to be honest cant remember where I got the bearing though got most from Dan I also had the rear prop redressed replaced the front prop and all the driveshafts when I did mine a few years ago think I was on about 160k I also replaced both diffs they were done at my local garage think Tommy might be a member on here I will ask him |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3350
Thanks Sandy, that's disappointing that your bearings are moving in the hub!
I think David they were not original parts the garage in the village got them for me and pressed them in but
Hopefully that’s all it is! I’ve got 4 genuine LR bearings to go on here.
| diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 491
Well done mate, its a lottery whether the drive shafts come out easy, sometimes they just slide out and other times they need beating out.
Thanks Dave |
| Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929
Sounds like you was pretty lucky with the shafts mate that's for sure. I've gotta do the cv joints on mine once I've done the welding but dreading the fact if they don't come loose I'm going to be on a certain creek without a paddle
Once I got the hub nut off I was bricking it after what I'd read... Not gonna lie, I did breath a sigh of relief when they both came out.
| Rambles Member Since: 16 Apr 2011 Location: UK Posts: 851
By intermediate drive shaft bearings….
No, there's a housing that bolts to the side of the engine with a separate bearing and oil seal on it to support the middle of the longer half shaft.
Got it.
Ahh yea, that's on the list of things I've already replaced on mine. |
| Roverlander Member Since: 16 Nov 2018 Location: Las Vegas Posts: 13
GraemeS, I'm looking into swapping in a locking diff for my open on on my 2007 4.4L. How did you control the e-locker or integrate into the vehicle systems, Terrain Response, etc? |
You would need something like an IID tool so that you could edit the CCF file on the car to tell it that you’ve fitted the locking diff.
| All times are GMT |
