Home > Technical (L322) > LED disco
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
LED disco
got pulled by the rozzers y.day , she explained that as i pulled away from them my rear lights were all twinkling / strobing , i was unable to replicate the symptoms until this morning while it was having its tracking done , the chap opened the drivers door and the same thing happened , any idea why this is / has occured folks ???
Post #625172 2nd Mar 2022 6:47pm
Merchy
All I can think of is.....as you quoted 'ALL the lights', due to the recent weather, has water got in and got to any of the wiring / control modules, especially as your fault appears to be random / intermittent, maybe check for any water ingress into the car, it's a start and costs nothing. Check all the rear compartments as well as other places.
Post #625180 2nd Mar 2022 7:23pm
400-ascona
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
The bulb check system sends current to the lights in a series of short blinks to detect a blown bulb. It does this periodically and for LED bulbs where incandescent were originally specked, this results in the LED strobing for a short period. Incandescent bulbs don't respond quick enough or bright enough to the system for it to be seen. 05 L322 4.2SC
2016 Discovery 4 Graphite
Lotus Carlton
Ascona 400
Volvo V70R AWD manual
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Mini Cooper S Works 2006
Post #625215 3rd Mar 2022 9:18am
bembo449
so its completely normal ???
Post #625245 3rd Mar 2022 4:28pm
garyRR
It doesn't say which car you have.
If it's a pre 2010 car that wasn't originally designed for LED bulbs, unless you buy good bulbs or good quality retrofit units with the correct size resistors in them, they'll flash and do all kind of funny things.
This applies to Canbus lights only though, which are all legally required driving lights plus the mirror puddles.
If it's a newer car designed for LED lights then, the PCB inside the light cluster may have reached end of life. 2015 Range Rover Autobiography 4.4 SDV8
Post #625288 4th Mar 2022 1:08am
bembo449
My cars a 06 ( ford era) SE thats been 2010 face lifted , had the rear lights out yesterday and there dry as a bone so is the boot pocket inside , they are genuine LR units too
Post #625294 4th Mar 2022 7:17am
400-ascona
Normal on 06. Not necessarily legal tho? 05 L322 4.2SC
Lotus Carlton
Ascona 400
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Post #625302 4th Mar 2022 8:21am
garyRR
You can install a resistor for each of the rear lights which are flickering also, which would stop it.
I'd consult an auto/audio electrician however - I don't know what sizes you'd install. 2015 Range Rover Autobiography 4.4 SDV8
Post #625303 4th Mar 2022 8:27am
bembo449
there are resistors soldered in on each side already pal Confused
Post #625368 4th Mar 2022 8:35pm
