![]() | Home > Technical (L322) > LED disco |
| Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238
All I can think of is.....as you quoted 'ALL the lights', due to the recent weather, has water got in and got to any of the wiring / control modules, especially as your fault appears to be random / intermittent, maybe check for any water ingress into the car, it's a start and costs nothing. Check all the rear compartments as well as other places. |
| 400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65
The bulb check system sends current to the lights in a series of short blinks to detect a blown bulb. It does this periodically and for LED bulbs where incandescent were originally specked, this results in the LED strobing for a short period. Incandescent bulbs don't respond quick enough or bright enough to the system for it to be seen. 05 L322 4.2SC
| bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817
so its completely normal ??? |
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494
It doesn't say which car you have.
My cars a 06 ( ford era) SE thats been 2010 face lifted , had the rear lights out yesterday and there dry as a bone so is the boot pocket inside , they are genuine LR units too |
Normal on 06. Not necessarily legal tho? 05 L322 4.2SC 2016 Discovery 4 Graphite Lotus Carlton Ascona 400 Volvo V70R AWD manual Suzuki 1200 Bandit Velocette Venom BMW R80/7 Daimler V8 250 Mini Cooper S Works 2006 |
You can install a resistor for each of the rear lights which are flickering also, which would stop it.
there are resistors soldered in on each side already pal |
| All times are GMT |
