![]() | Home > Technical (L322) > P040D-00 (2F) EGR temperature sensor replacement |
| MTG2020 Member Since: 24 Feb 2020 Location: Caerphilly Posts: 35
Yes. It was in RP before the yellow DPF warnings. |
No EML.
No have the EML light, haven't read it yet, but assume it will relate to the red DPF warning.
i most definitely would.... |
| physio Member Since: 31 Aug 2020 Location: Essex Posts: 6
Hi Great detail. Do you think a sooted up, choked EGR valve would give the same error code. |
Hi
| JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 297
Me too, only an occasional fault though! |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875
I have had the PO 40D fault permanently for at least 5 years, but I have never seen PO486 ?
Now it’s getting a bit more regular. The fault is always there but sometimes it goes into RP, no other fault codes come up and it does eventually clear, either on thE IID or just by leaving it for a while..
| Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 |
Well, so far I`m stripped down and have cut the sensor with a hack saw blade? moved the heat shield out of the way and got the socket on.
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555
Mine was tight but with a 'crack' it moved
Yes, I'm sure it went on as I checked each time with the borescope nice to have the light on the end? Having a cup of tea now, waiting for some more CRC penetration? then have another go, not in any rush. |
Well got it done over 3 days? and plenty of cups of tea.
Well done Tinman, welcome to the P040D-00 club |
