![]() | Home > My Range Rover > Back with another Supercharged |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3282 ![]() ![]() ![]() |
@Superspoons - I've probably gone way OTT with mine due to the fact I've had the ramp. I've probably done a fair amount of work that it didn't actually need. Not like me to go charging straight in though apparently... |
Following on from my PCV thread here: https://www.fullfatrr.com/forum/topic63251.html
Tonight saw a bit more time on the lathe to make an adapter for the smoke tester |
Seriouslthinkingaboutit Member Since: 12 Mar 2022 Location: Essex Posts: 98 ![]() ![]() ![]() |
Hi David
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 607 ![]() ![]() ![]() |
WOW |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1008 ![]() ![]() |
Nice work |
Look on the bright side |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Ouch!!!! Just when you thought that you were near the end |
I guess it’s lucky I found it before or skipped teeth or snapped. If it had skipped or snapped it would have made one hell of a mess.
Just priced everything up…
TBF half of that is because you have a seat of heads on the shelf and are going to swap them in.
My car has had LPG on it for years. The AJV8 engines suffer on LPG due to the valve seats being soft.
Thanks
