![]() | Home > Technical (L322) > 2011 range rover l322 Glovebox wiring |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
Have a look at this page, last post
daveturbo Member Since: 11 Nov 2012 Location: county durham Posts: 107 ![]() ![]() ![]() |
Thanks but that's the earlier Range Rover. Mercedes AMG w207
I wouldn't have imagined they would be that different Got - 2017 SDV8 Autobiography in Loire Blue
i have just checked and the fuse 16 is the diesel heater on mine and wiring configuration is different layout and colours. Mercedes AMG w207
Good old JLR |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3329 ![]() ![]() ![]() |
Amazingly, the fuse for the glovebox is in the fusebox in the boot.
Thank you i will check it later. i have checked all the fuses before but at least i can see if there is a feed there at the correct fuse. Mercedes AMG w207
Fuse is fine and has a 12 volt feed. Mercedes AMG w207
hawkeye651 Member Since: 21 Oct 2019 Location: Melksham Posts: 23 ![]() ![]() ![]() |
Did you ever resolve this issue - I have the same problem ..... 2012 L322 4.4 TDV8 - Current
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
On my 2011, the glove box was actually wired to the interior light fuse, which was actually wired to something else labelled entirely different to what the manual says.
Found 5 wires with broken wire connectors under the drivers side sill trim cover, glovebox and Auto wipers lights now working. Mercedes AMG w207
