Home > Technical (L322) > 2011 range rover l322 Glovebox wiring
daveturbo
I still cant open either glove box relay ok ,tried new switch ,actuators work fine. my switch does not illuminate and there is no power supply, does anyone have a wiring diagram please ,many thanks Dave. Mercedes AMG w207
E class Cabriolet
Overfinch L322 4.4 tdv8
1987 sierra rs cosworth 3 door white.
1985 escort rs turbo series one.
1992 sierra sapphire 4x4 cosworth red
1993 sierra sapphire cosworth 4x4 silver
1993 sierra sapphire cosworth 4x4 white
1995 ducati 916sp.
Post #629769 26th Apr 2022 12:30pm
Have a look at this page, last post
https://www.fullfatrr.com/forum/topic39285-15.html Got - 2017 SDV8 Autobiography in Loire Blue
Post #629772 26th Apr 2022 12:55pm
daveturbo
2011 Range rover Glovebox
Thanks but that's the earlier Range Rover. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #630504 3rd May 2022 11:19am
I wouldn't have imagined they would be that different Got - 2017 SDV8 Autobiography in Loire Blue
Post #630505 3rd May 2022 11:27am
daveturbo
i have just checked and the fuse 16 is the diesel heater on mine and wiring configuration is different layout and colours. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #630515 3rd May 2022 12:26pm
Good old JLR Shocked Got - 2017 SDV8 Autobiography in Loire Blue
Post #630547 3rd May 2022 4:40pm
dhallworth
Amazingly, the fuse for the glovebox is in the fusebox in the boot.
From the handbook for a 2012 L322...
Rear Loadspace Fusebox
Fuse number 11 - 5A - Tan - Glovebox.
Post #630548 3rd May 2022 4:54pm
daveturbo
Thank you i will check it later. i have checked all the fuses before but at least i can see if there is a feed there at the correct fuse. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #630615 4th May 2022 12:02pm
daveturbo
Fuse is fine and has a 12 volt feed. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #630634 4th May 2022 2:24pm
hawkeye651
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Did you ever resolve this issue - I have the same problem ..... 2012 L322 4.4 TDV8 - Current
2012 AM Rapide - Current
2009 Discovery - Gone
Post #692154 8th May 2024 3:53pm
garyRR
On my 2011, the glove box was actually wired to the interior light fuse, which was actually wired to something else labelled entirely different to what the manual says.
It's worth pulling every fuse to check. 2015 Range Rover Autobiography 4.4 SDV8
Post #692169 8th May 2024 5:44pm
daveturbo
Glovebox Fixed
Found 5 wires with broken wire connectors under the drivers side sill trim cover, glovebox and Auto wipers lights now working. Mercedes AMG w207
E class Cabriolet
1995 ducati 916sp.
Post #693509 28th May 2024 9:09pm
