![]() | Home > Technical (L322) > 2011 range rover l322 Glovebox wiring |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837
Have a look at this page, last post
| daveturbo Member Since: 11 Nov 2012 Location: county durham Posts: 107
Thanks but that's the earlier Range Rover. Mercedes AMG w207
I wouldn't have imagined they would be that different Got - 2017 SDV8 Autobiography in Loire Blue
i have just checked and the fuse 16 is the diesel heater on mine and wiring configuration is different layout and colours. Mercedes AMG w207
Good old JLR |
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3346
Amazingly, the fuse for the glovebox is in the fusebox in the boot.
Thank you i will check it later. i have checked all the fuses before but at least i can see if there is a feed there at the correct fuse. Mercedes AMG w207
Fuse is fine and has a 12 volt feed. Mercedes AMG w207
| hawkeye651 Member Since: 21 Oct 2019 Location: Melksham Posts: 23
Did you ever resolve this issue - I have the same problem ..... 2012 L322 4.4 TDV8 - Current
| garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1493
On my 2011, the glove box was actually wired to the interior light fuse, which was actually wired to something else labelled entirely different to what the manual says.
Found 5 wires with broken wire connectors under the drivers side sill trim cover, glovebox and Auto wipers lights now working. Mercedes AMG w207
