![]() | Home > Technical (L322) > Tow Bar Help! TDV8 2011 |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3313 ![]() ![]() ![]() |
I believe the armature is no longer available brand new so you'd need to look at second hand if you wanted the genuine Land Rover kit. There's usually a few on eBay at any given time.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Don`t forget to tell the car you have a 13 pin electrics otherwise the reverse beeper will not turn off when you select reverse when towing. |
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 104 ![]() ![]() ![]() |
Might widen your options by going with the 2 7 pin sockets on the car and getting one of the adapters that wire the 2 x 7's into the 13. I'm guessing you have a 13 pin caravan.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
The Westfalia amartures are SUPER expensive (£300+ just for the attachment and not the towbar assembly or wiring).
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 612 ![]() ![]() ![]() |
I purchased a second-hand Westfalia tow bar and fitted my self, not a difficult job, a little heavy but easily doable.
Davidmudley Member Since: 27 Dec 2021 Location: Surrey Posts: 80 ![]() ![]() |
I did the same as Bigbo and found it an easy approach, the sand blasting and painting (£125) was well worth it as the armature and fittings looked like new.
All Tow bars have to be type approved so, it baffles me why anyone would buy a 2nd hand Westfalia bar needing new fixings, shot blasting and powder coating at great expense, over just buying a brand new type approved bar.
