Home > My Range Rover > Back with another Supercharged |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2970 |
One of the cam journals has some scoring on it so I’m not prepared to refit it.
9th May 2022 12:11am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2180 |
Ah yes I can see - what lpg kit was it? Current stable:
9th May 2022 10:44am |
It’s a BRC kit with a Fly SF ECU, twin reducers and pumped flashlube. It runs perfectly on it and will hold LPG right through the revs at WOT throttle up through 2nd, 3rd and 4th gear.
9th May 2022 11:22pm |
Some questions - what do you think has caused the scoring? Failing oil pump?
10th May 2022 7:39am |
Seriouslthinkingaboutit Member Since: 12 Mar 2022 Location: Essex Posts: 98 |
On bedding in the camshafts - I assume you’ve also checked the Jag forums for this engine or the 4.0 (if similar) as much wider usage in XK and XJ
10th May 2022 8:19am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
would it be worth looking at having them re-profiled? 2012 Vogue 4.4 TDV8 - Current
10th May 2022 8:38am |
No idea what caused the scoring to be honest. I’d have thought if the oil pump was failing I’d have had oil pressure warnings or noise from the top end. This one was silent and other then the misfire when cold ran perfectly.
10th May 2022 10:28am |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 835 |
Have you considered Kent cams for new made in house replacements ? |
10th May 2022 11:48am |
Just off the phone to Kent Cams.
10th May 2022 1:22pm |
These look clean maybe worth a look or more photos?
10th May 2022 11:49pm |
I saw those last night, they’re probably the best of the ones on eBay.
11th May 2022 12:06am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1141 |
Looking at the photographs of the camshafts, personally I would DEFINITELY fit a new oil pump, that would vastly reduce the risk of the same happening again.
11th May 2022 7:08am |
Good point you won’t want to sell that for a long while after doing all that!
11th May 2022 7:13am |
I've been pondering the idea of the oil pump swap but to do it you need to remove the sump and to remove the sump you need to remove the engine from the car.
11th May 2022 2:02pm |
