Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 632 |
I have in the past dismissed the fronts because of how the car feels when going over speed bumps. I would expect that the fronts would be harsh but the rears would be softer. I don’t feel that in mine..l That being said, you and coopss may be right and we will not know unless we swap the fronts. As mentioned before it is on the cards for me, but way, way down the list. Swapping of the accelerometers is more likely, but I’ve not looked how you do that to the ones not in the boot. Are they just sat behind the wheel liners? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
12th May 2022 6:59pm |
About £300 rears and £600 fronts I believe. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
12th May 2022 7:00pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7651 |
About £350 plus VAT as opposed to £200 plus VAT…..
12th May 2022 7:02pm |
They are better prices than from Duckworths!
12th May 2022 8:14pm |
I did a bit of shopping around when I needed my rears changing.
12th May 2022 8:54pm |
I’m guessing the other accelerometers are either behind the wheel arch liners or inside, behind the kick panel where your feet are. Was gonna ask if anyone knew for sure…..
12th May 2022 8:58pm |
Oooo that’s excellent news, and ties in with what a few others have found.
15th May 2022 11:35pm |
I wonder if just putting a front wheel up a bank might have the same effect? Like making the shock compress…..
15th May 2022 11:38pm |
That is good news MarianaWestminster!
16th May 2022 7:08am |
Would lowering the car also have the same effect? Maybe raising fully then lowering? Or even possibly lowering to the bump stops for even more compression? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
16th May 2022 7:13am |
Yeah, I thought that…. as the shock would have to compress to let the car down, along with the air bag. That would be all 4 corners though, and, well, you don’t want to cause an issue you didn’t have before
16th May 2022 8:37am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2795 |
Maybe bouncing the car made the AD ECU think it was traversing rough ground and it softened off the damping. No one really knows how this system actually works. 2012 TDV8 Vogue (L322) |
16th May 2022 8:41am |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 595 |
Good ideas regards lowing the suspension to compress the shocks 👍
16th May 2022 10:05am |
What tyres and size are you running BTW. I commented on Sam's latest Youtube video that his oversized all terrain tyres will be stiffer than normal road tyres which will make for a harsher ride just as low profile road tyres will. 2012 TDV8 Vogue (L322) |
16th May 2022 10:11am |
