Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322!
Page 11 of 30 <123 ... 101112 ... 282930>
LandyManSam
Ireland 2012 Range Rover Vogue TDV8 Santorini Black
Jayk69 wrote:
if you can get hold of a Icarsoft V2 you can monitor in Realtime the voltage and NM value of each damper.
in theory if you see the voltage drop, but the NM value does not it would indicate the valve on the damper may be stuck or the fluid in the damper has past its best or leaked away (you cannot detect a leak on the fronts unless you take the air bags off)
just a thought
So I think it should be current (A) rather than volts, maybe the iCarsoft is just labelling this incorrectly.
Also the stiffness value (Nm) will be a calculated value from the current demand (basically just reading off a scale), so it won't be reporting real-time stiffness data unfortunately. Sam's Motor & Machine YouTube Channel: https://www.youtube.com/channel/UCgNSRjY0I9FCzsi9ku3ccbw
Home of the 'Cheapest 4.4 TDV8 Range Rover"
Post #632218 19th May 2022 9:47am
colalowe
United Kingdom 2012 Range Rover Autobiography TDV8 Buckingham Blue
Jayk69 wrote:
Just to update
when i engage drive the shocks get a voltage of 1.5 volts this drops the NM value from 899NM to 250NM on the rears.
I will try to plug in and take some pics of all four to give people a baseline to work from.
So if I engage drive and get someone to keep their foot on the brake all the dampers should be at the soft setting?, so if I do a bounce test then they should all bounce roughly the same if they are all working, do you think that would work??
Post #632238 19th May 2022 1:56pm
LandyManSam
I think they energize once you start moving, rather than just engaging drive - but could be wrong there, been a while since I had it plugged into SDD. Sam's Motor & Machine YouTube Channel: https://www.youtube.com/channel/UCgNSRjY0I9FCzsi9ku3ccbw
Post #632239 19th May 2022 1:58pm
MarianaWestminster
Not trying to detract from the core issue in this thread but I'm feeling my steering is heavier than it should be lately.
I had this issue on my last l322 and never fixed it just some days it was nice others not.
Now I'm wondering if the 2 faults could be connected?
Could I ask how you feel about the steering weight on your L322s chaps?
Post #632319 20th May 2022 11:53am
RRover
2012 Range Rover Westminster TDV8 Causeway Grey
Mine just fine! Sweet, in fact... Some of those over-priced tyres can make it seem heavier, for some reason, though who knows why?!? Maybe to make them wear out faster?!? Neutral
Post #632324 20th May 2022 12:19pm
LandyManSam
Mine feels fine, not finger-tip light but nearly. That's even with my big A/T tyres on.
I seem to remember a problem that the early L322s had with their 'servotronic' valves for the steering - which is meant to vary steering weight according to speed. I'd be surprised if it's related to the harsh ride, but I won't say it's impossible! Sam's Motor & Machine YouTube Channel: https://www.youtube.com/channel/UCgNSRjY0I9FCzsi9ku3ccbw
Post #632327 20th May 2022 12:33pm
MarianaWestminster
Thanks for your input guys!
Landymansam I was actually watching one of your videos last night and thought to myself 'mine certainly isnt that light!'
I tried replacing the servotronic on my last l322 and it didn't make a difference at all.
(That car also had a new rack and a known good used pump but like I say I never sorted it. My first L322 Westminster
was as you describe sam almost fingertip light)
I will go away and ponder it
Post #632329 20th May 2022 12:39pm
mjdronfield
My steering is fine… light at slow speeds, bit heavier as speed builds, though to be fair, it normally has a belly resting on it, so self centering not the best 🤣.
My suspension going harsh coincided with me upping the tyre pressures a bit for load. If that’s a factor, it may have jiggled the shocks more and potentially unstuck or stuck one of those solenoid valve things… if we are guessing.
Just been out, and I’ve deduced that at 30 or 40 I can feed the steering on smoothly, with my hand at the top position down to about 9 or 8 o’clock… and the tyres will start to squeal before the body starts to roll. The front of the car is still flat… or at least not rolled enough for me to notice whilst trying not to slide out the seat. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #632338 20th May 2022 1:36pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
according to live data as soon as you go into drive, voltage goes to 1.5 and nm goes to 250NM this is for the rears will check the fronts 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #632376 20th May 2022 8:01pm
Reidsr
United Kingdom 2016 Range Rover SDV6 Santorini Black
After Sam has changed his front struts and found no change I'm now thinking it must be bush related. I have had the bushes checked but i think they have just done the quick test that MOT require for suspension bushes not for subframe mounts. It feels as though my whole subframe is loose and moving about! But no clunking which might counteracts the claim. Im fed up of how it drives.
Post #632950 26th May 2022 2:07pm
Jayk69
has Sam changed them then? cannot see a video have i missed something 2012 Vogue 4.4 TDV8 - Current
Post #633061 27th May 2022 2:00pm
mjdronfield
Not recently, though Sam said in a video that he had put non CVD units on, and it was pretty much the same.
I’m assuming it’s that.
He has still yet to replace with new CVD fronts.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #633067 27th May 2022 2:55pm
DrRob
Correct. We are all waiting with anticipation to prove the theory correct Thumbs Up Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #633068 27th May 2022 3:12pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Me too… although I am delayed due to needing new control arms too. I have a £1,700 bill for all those parts if I include the struts too. Big Cry Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #633120 28th May 2022 8:39am
MarianaWestminster
UPDATE
My suspensions gone stiff again this week unfortunately!
I've just fitted the rear dampers that I bought off coopss and it's not helped other than the back of the car doesn't feel as bouncy now.
This coupled with stiff steering is really making the car a bear to drive.
Kind of regretting buying another L322 now.
Hopefully one day we will have a fix but for now I'm out of ideas
Post #633126 28th May 2022 12:11pm
