![]() | Home > Technical (L322) > Restricted Performance Fault TDV8 4.4 - 1750 rpm on Motorway |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3246 ![]() ![]() ![]() |
I had almost exactly the same, especially when on cruise control. no fault codes but it was filling up the dpf. what is your dpof reading?
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 697 ![]() ![]() ![]() |
1750rpm……..in top?…………that must be reaching top end of 90mph +? Yikes!😁
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 265 ![]() ![]() ![]() |
My gearing has 1750rpm in the low to mid 70 mpg range.
Dave lincs Member Since: 31 Dec 2021 Location: louth Posts: 42 ![]() ![]() |
Hi Mike my 4.4 tdv8 at 50mph is over 1000 rpm so if you say 70mph is 1750 rpm something is not right have you had it on a code reader yet
Mine has always been around 1750 rpm for driving in the low to mid 70 mph range
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3300 ![]() ![]() ![]() |
Mine is about 1400 rpm at 70mph so something very wrong if it's 1750rpm at 70mph - have you tried command shift to check it's in 8th gear? 2012 TDV8 Vogue (L322) |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4341 ![]() ![]() ![]() |
That's way too high an rpm at 70mph....
Seriouslthinkingaboutit Member Since: 12 Mar 2022 Location: Essex Posts: 98 ![]() ![]() ![]() |
1750 rpm sounds like it's not in top gear 2007 4.2SC Buckingham Blue
There is another thread where someone's car wouldn't go into top due to mismatched tyres (slightly different tread depth). Seems that if the ABS speed sensor picks up even a slight difference across the axle it thinks the car is cornering and things don't work like they should. 2012 TDV8 Vogue (L322) |
I had a closer look on the way home this evening. Looks like it is closer to 1600 rpm than 1750 rpm but it is definitely in top gear when I use the paddles. |
What size wheels and tyre’s do you have. Have you compared the speedo mph with a gps speed on a phone app? 2012 TDV8 Vogue (L322) |
20" wheels that it came with. Have done over 10K since I've owned it and haven't changed a thing. |
This is mine
1400rpm at 70mph here on 255 55 20 tyres Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
