Home > Technical (L322) > Restricted Performance Fault TDV8 4.4 - 1750 rpm on Motorway |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3062 |
I had almost exactly the same, especially when on cruise control. no fault codes but it was filling up the dpf. what is your dpof reading?
22nd May 2022 8:26pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 662 |
1750rpm……..in top?…………that must be reaching top end of 90mph +? Yikes!😁
23rd May 2022 7:43am |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 223 |
My gearing has 1750rpm in the low to mid 70 mpg range.
23rd May 2022 12:08pm |
Dave lincs Member Since: 31 Dec 2021 Location: louth Posts: 39 |
Hi Mike my 4.4 tdv8 at 50mph is over 1000 rpm so if you say 70mph is 1750 rpm something is not right have you had it on a code reader yet
23rd May 2022 12:30pm |
Mine has always been around 1750 rpm for driving in the low to mid 70 mph range
23rd May 2022 2:25pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2695 |
Mine is about 1400 rpm at 70mph so something very wrong if it's 1750rpm at 70mph - have you tried command shift to check it's in 8th gear? 2012 TDV8 Vogue (L322) |
23rd May 2022 2:40pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4235 |
That's way too high an rpm at 70mph....
23rd May 2022 2:45pm |
Seriouslthinkingaboutit Member Since: 12 Mar 2022 Location: Essex Posts: 98 |
1750 rpm sounds like it's not in top gear 2007 4.2SC Buckingham Blue
23rd May 2022 4:02pm |
There is another thread where someone's car wouldn't go into top due to mismatched tyres (slightly different tread depth). Seems that if the ABS speed sensor picks up even a slight difference across the axle it thinks the car is cornering and things don't work like they should. 2012 TDV8 Vogue (L322) |
23rd May 2022 4:07pm |
I had a closer look on the way home this evening. Looks like it is closer to 1600 rpm than 1750 rpm but it is definitely in top gear when I use the paddles. |
23rd May 2022 4:46pm |
What size wheels and tyre’s do you have. Have you compared the speedo mph with a gps speed on a phone app? 2012 TDV8 Vogue (L322) |
23rd May 2022 5:10pm |
20" wheels that it came with. Have done over 10K since I've owned it and haven't changed a thing. |
23rd May 2022 9:51pm |
This is mine
24th May 2022 5:48am |
1400rpm at 70mph here on 255 55 20 tyres Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
24th May 2022 7:51am |
