![]() | Home > Maintenance & Mods (L322) > Sunroof does not open |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4350 ![]() ![]() ![]() |
Personally I would leave it well alone |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1414 ![]() ![]() |
Agreed, better stuck shut than stuck open, just trying to remember the last time we've had ours open, no can't remember tbh |
nemmi69 Member Since: 16 Jun 2015 Location: Peterborough Posts: 109 ![]() ![]() ![]() |
me being anal and want everything working What doesn't kill you is just bidding it's time. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3987 ![]() ![]() ![]() |
You could start by removing the access panel shown 1 in the picture. This allows access to the motor and drive shaft
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
Back in the olden days there used to be a manual override using an Allen key or similar.
Cheers, will give it a go What doesn't kill you is just bidding it's time. |
Just a thought, it’s possible the sunroof need’s initialised for some reason.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494 ![]() ![]() |
Try the initialisation procedure. If not, let it remain a fixed sunshine roof. 2015 Range Rover Autobiography 4.4 SDV8 |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3386 ![]() ![]() ![]() |
Never opened mine - never will. Best left alone IMO….. 2012 TDV8 Vogue (L322) |
Tdtj Member Since: 29 Sep 2021 Location: East kilbride Posts: 207 ![]() ![]() |
Mine opens and tilts. I was worried at first as to whether I should try it or not given the mileage approx164000 but I thought |
What's the best "grease" type to use on the rails? Just thinking as part of some preventative maintenance... |
I used silica grease, it must be ok as my sunroof still works. |
I’m thinking I may give mine a dab of lubricant this weekend 2016 4.4 diesel |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Read the above post and couldn't help thinking................whilst your at it, you could also put some lube on the roof rails at the same time |
