Home > Maintenance & Mods (L322) > Sunroof does not open
nemmi69
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Barolo Black
Its come round to fixing the sunroof. It has never worked since I bought it.
Checked fuse and its OK. Cannot say I hear anything when I press the switch but then they are not the noisest motors.
Checked site and all topics seem about stuck open or sticky. Im sure others have had to deal with this so surprised its not a topic What doesn't kill you is just bidding it's time.
Post #633161 29th May 2022 3:13pm
DrRob
Personally I would leave it well alone Wink Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #633162 29th May 2022 3:24pm
dingg1
Agreed, better stuck shut than stuck open, just trying to remember the last time we've had ours open, no can't remember tbh Laughing Cool
Post #633163 29th May 2022 4:00pm
nemmi69
me being anal and want everything working What doesn't kill you is just bidding it's time.
Post #633164 29th May 2022 4:04pm
You could start by removing the access panel shown 1 in the picture. This allows access to the motor and drive shaft
I would try spraying everything with wd 40 and see if anything happens.
Post #633168 29th May 2022 4:57pm
mjdronfield
Back in the olden days there used to be a manual override using an Allen key or similar.
Not sure if you can still do that… at least give you a feel for if it’s jammed up or not.
Or you may find the switch disconnected…. And then have to see why…..
My sunroof is nearly always open… even at night sometimes…..
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #633169 29th May 2022 5:08pm
nemmi69
Cheers, will give it a go What doesn't kill you is just bidding it's time.
Post #633171 29th May 2022 5:41pm
Just a thought, it’s possible the sunroof need’s initialised for some reason.
Sorry about the text quality but if you enlarge it it can be just about read
Post #633172 29th May 2022 5:47pm
garyRR
Try the initialisation procedure. If not, let it remain a fixed sunshine roof. 2015 Range Rover Autobiography 4.4 SDV8
Post #633180 29th May 2022 7:15pm
JayGee
Never opened mine - never will. Best left alone IMO….. 2012 TDV8 Vogue (L322)
Post #633198 29th May 2022 10:34pm
Tdtj
Mine opens and tilts. I was worried at first as to whether I should try it or not given the mileage approx164000 but I thought Censored it and hey presto no issues whatsoever. Have faith Laughing 2016 4.4 diesel
Post #633241 30th May 2022 1:30pm
DrRob
What's the best "grease" type to use on the rails? Just thinking as part of some preventative maintenance... Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #633245 30th May 2022 1:46pm
I used silica grease, it must be ok as my sunroof still works. Thumbs Up
Post #633250 30th May 2022 3:08pm
Tdtj
I’m thinking I may give mine a dab of lubricant this weekend 2016 4.4 diesel
Post #633257 30th May 2022 5:06pm
Merchy
Read the above post and couldn't help thinking................whilst your at it, you could also put some lube on the roof rails at the same time Whistle
...getting my coat and now leaving Rolling with laughter
Post #633265 30th May 2022 5:50pm
