![]() | Home > Maintenance & Mods (L405) > First oil change - please help a fool |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3848 ![]() ![]() ![]() |
https://www.toolstation.com/draper-expert-...tor/p51293
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3925 ![]() ![]() ![]() |
I might have a go at this, however what do I do with the old engine oil? Geoff |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Thank you @Baltic Blue - ordered. |
I'm pretty sure you can usually take it to your local tip. What do I put here then? |
Geoff,
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Don't forget to reset your service interval or the car's computer won't have a clue it's been done so oil dilution reading will continue to climb and cause warnings.
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
The price for the oil pump is a bit strong.
Smith and Allan oil OK? Geoff |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Smith and Allan oils are excellent and they are very helpful if you have any questions.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 778 ![]() ![]() ![]() |
I use one of these...
And yes, change the filter too....
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1401 ![]() ![]() |
Oil reset L405 pop bonnet, leave driver door open, press full. Brake and accelerator pedals for 10 secs Oil filter 36mm socket required and 28nM torque. the 10L Draper is a dream and takes all your oil and fuel without having to empty and start again zero mess ![]() ![]() To read Oil level Simply pull the bonnet release, get in and press the start buttton (without your foot on the brake). Press "OK" to clear any warnings ( including'bonnet open' )- once they are clear, do the oil check as normal but when it comes up "unavailable" press 'cancel' on the cruise control twice - your oil level shows! 2018 SE SDV8 4.4 Byron Blue |
Thanks all. Much appreciated.
I have put several posts up showing oil change procedure for 4.4 tdV8 , mine is an L322, but your L405 is virtually identical.
