Home > Maintenance & Mods (L405) > First oil change - please help a fool
Page 1 of 3 123>
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
As almost all my journeys are short, my SDV8 suffers from oil dilution.
Last time I needed an "oil service" I had my local and excellent indy do it.
But, apparently, it's a simple DIY task. So easy even a numpty like me can do it.
I believe I need - links would be great:
    Something to suck the old oil out
    New oil - what do I buy?
... do I need to change the filter too - if so what do I get and is it easy?
Finally, where do I "plug in" the oil extracting device - a picture would be excellent.
Thanks in advance and apologies for all the stupid questions. What do I put here then?
Post #633216 30th May 2022 10:13am
Baltic Blue
https://www.toolstation.com/draper-expert-...tor/p51293
This is the most popular oil syphon .
It has a 10 litre tank .
Cheaper versions are available, but their smaller tanks risk dirty old oil spillages.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #633217 30th May 2022 10:47am
supershuttle
I might have a go at this, however what do I do with the old engine oil? Geoff
Post #633218 30th May 2022 10:54am
GAC23
Thank you @Baltic Blue - ordered. Smile What do I put here then?
Post #633219 30th May 2022 10:57am
GAC23
I'm pretty sure you can usually take it to your local tip. What do I put here then?
Post #633221 30th May 2022 10:59am
Baltic Blue
Geoff,
Pour the old oil back into the empty containers and take them to your local rubbish depot where they will despose of it for you.
Mike.
If you get any empty 5 litre containers from screenwash, add blue etc, keep them for the job. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #633222 30th May 2022 11:03am
DrRob
Don't forget to reset your service interval or the car's computer won't have a clue it's been done so oil dilution reading will continue to climb and cause warnings.
No idea on an L405 but it requires an OBD2 plug in for the L322....most of us have a GAP IID Bluetooth for this and a 100 other reasons. Buy one Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #633223 30th May 2022 11:16am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
The price for the oil pump is a bit strong.
Here's a 9l one for a lot less.
https://www.aimtools.co.uk/products/481509 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #633224 30th May 2022 11:17am
supershuttle
Smith and Allan oil OK? Geoff
Post #633233 30th May 2022 12:38pm
Merchy
Smith and Allan oils are excellent and they are very helpful if you have any questions.
No connection to the company, just a satisfied customer.
Post #633271 30th May 2022 6:41pm
knwatkins
I use one of these...
https://www.ebay.co.uk/itm/134035200459
Also use S&A oils, been using them for years Thumbs Up
Old oil is taken to the local tip and dumped in their recycling tank. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #633281 30th May 2022 9:04pm
knwatkins
And yes, change the filter too....
LR022896 from LR
OEM is Mahle OX153/7D2 Kev
Post #633282 30th May 2022 9:08pm
Kot
Oil reset L405 pop bonnet, leave driver door open, press full. Brake and accelerator pedals for 10 secs
Oil filter 36mm socket required and 28nM torque.
the 10L Draper is a dream and takes all your oil and fuel without having to empty and start again zero mess Rolling with laughter Rolling with laughter
To read Oil level
Simply pull the bonnet release, get in and press the start buttton (without your foot on the brake).
Press "OK" to clear any warnings ( including'bonnet open' )- once they are clear, do the oil check as normal but when it comes up "unavailable" press 'cancel' on the cruise control twice - your oil level shows! 2018 SE SDV8 4.4 Byron Blue
Post #633285 30th May 2022 9:27pm
GAC23
Thanks all. Much appreciated.
Couple more - daft - questions:
What numbers does the oil need to have?
Can anyone recommend the torque wrench I should get - is a halfords one good enough?
Where do I connect the oil drainer pump to? What do I put here then?
Post #633316 31st May 2022 9:32am
Baltic Blue
I have put several posts up showing oil change procedure for 4.4 tdV8 , mine is an L322, but your L405 is virtually identical.
Mine is a Draper 3/8 sq drive. 36mm socket, 27Nm torque.
Post #633321 31st May 2022 10:06am
Page 1 of 3 123>
