![]() | Home > Maintenance & Mods (L405) > First oil change - please help a fool |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
https://www.toolstation.com/draper-expert-...tor/p51293
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3962
I might have a go at this, however what do I do with the old engine oil? Geoff |
| GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670
Thank you @Baltic Blue - ordered. |
I'm pretty sure you can usually take it to your local tip. What do I put here then? |
Geoff,
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Don't forget to reset your service interval or the car's computer won't have a clue it's been done so oil dilution reading will continue to climb and cause warnings.
| V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424
The price for the oil pump is a bit strong.
Smith and Allan oil OK? Geoff |
| Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238
Smith and Allan oils are excellent and they are very helpful if you have any questions.
| knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782
I use one of these...
And yes, change the filter too....
| Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1442
Oil reset L405 pop bonnet, leave driver door open, press full. Brake and accelerator pedals for 10 secs Oil filter 36mm socket required and 28nM torque. the 10L Draper is a dream and takes all your oil and fuel without having to empty and start again zero mess To read Oil level Simply pull the bonnet release, get in and press the start buttton (without your foot on the brake). Press "OK" to clear any warnings ( including'bonnet open' )- once they are clear, do the oil check as normal but when it comes up "unavailable" press 'cancel' on the cruise control twice - your oil level shows! 2018 SE SDV8 4.4 Byron Blue |
Thanks all. Much appreciated.
I have put several posts up showing oil change procedure for 4.4 tdV8 , mine is an L322, but your L405 is virtually identical.
