Home > My Range Rover > Back with another Supercharged
Page 32 of 58 <123 ... 313233 ... 565758>
dhallworth
Laughing Laughing Laughing
That's in the criteria to join is it not? Very Happy 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #633838 6th Jun 2022 11:48pm
Hmmmmm, I think you may just be right sir… 👍
Post #633872 7th Jun 2022 10:16am
dhallworth
Well, time for a few updates…
I decided that I’ve spent enough for now so rather then fitting a brand new Supercharger I’m going with the one I’ve rebuilt. It should be nice and quiet after being rebuilt.
So… Thursday saw the Supercharger reassembled.
First step was a bead of Loctite 518 applied around the casing before the rotor pack was installed. Once the rotor pack was installed another bead of Loctite 518 was applied around the top of the rotor back where the snout assembly seals. It was then reassembled and all of the bolts torqued down to 19nm.
It was then left for 24hrs before being refilled with Supercharger oil. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #633962 7th Jun 2022 7:50pm
dhallworth
I noticed when I was removing the LPG kit that whoever fitted it had reworked the air suspension compressor into a random metal box and it had just been thrown into the boot and surrounded by foam padding and the driers and valve blocks were just thrown in the spare wheel well.
As the LPG tank is being removed I decided I’d remove all the air suspension stuff and replace it properly.
I was going to buy an enclosure for the compressor and reassemble mine into it but Land Rover want nearly £900 for an empty enclosure so that was a non starter! So… after a trip to eBay and £160 later, this arrived after 24hrs.
Post #633964 7th Jun 2022 7:54pm
dhallworth
So… me being me I couldn’t just fit it as it arrived - Could I?
Compressor internals were all removed from the frame. I noticed on the compressor there’s a date stamp of July 2020 so it’s been replaced fairly recently Smile
That left me with the base place sitting on the toolbox.
I cleaned it and then set about bursting the rust bubbles with my Snap-On Polishing and prep tool.
I gave the base a coating of Hydrate 80. I did all around the seam on the base too and then turned my attention to the lid giving it the same treatment.
As I turned it round I saw a dent in the lid. It annoyed me more then it should have so I dealt with that. Filler and sanding were the order of the evening.
After.
I’ll give the Hydrate 80 24hrs to do it’s thing and will then give it a coat of Zinc primer to stop it rusting again and will then spray it with a matte black paint.
Like I said above though - this shouldn’t have annoyed me as much as it did seeing as it’ll be under the boot floor and underneath the spare wheel but at least it’ll be done right.
I’m going to do the boot floor properly with rust treatment and paint once the LPG tank is out before refitting the compressor as well.
That’s all for now Smile Cams should be here by the weekend thankfully!
Post #633966 7th Jun 2022 8:01pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Top job Thumbs Up Thumbs Up
Post #633967 7th Jun 2022 8:10pm
Very anal... I say this as a compliment.... Thumbs Up Pete
-Click here for Thread-
Post #633972 7th Jun 2022 9:11pm
dhallworth
Nothing much done tonight other then a couple of coats of zinc primer.
Few marks have appeared under the primer on the back half of this so will likely give it a gentle rub down and another coat tomorrow evening.
Hopefully give them a couple of coats of matte black tomorrow evening.
Had a dispatch notification for the cams today too. ETA is Friday. 😁 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #634079 8th Jun 2022 6:28pm
Sandyt
Busy day tomorrow then I should be doing some of the jobs to the same level you do David great job Thumbs Up
Post #634222 9th Jun 2022 9:49pm
dhallworth
Cheers Sandy Smile
You saying how well yours drives at over 200k has been part of the reason for me to keep going with this one!
Injectors are boxed up and being sent away tomorrow for checking and refurbishing if necessary.
Seeing as I've removed the LPG I want to ensure that the petrol system is 110% before building it all back up as it's not something I want to be dismantling again!
Post #634224 9th Jun 2022 10:39pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Keep up the good work David, it will all be worth it when you have finished Thumbs Up 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #634236 10th Jun 2022 6:52am
dhallworth
Getting impatient now!
Post #634250 10th Jun 2022 10:58am
Jayk69
your impatient Shocked i am impatient for your next update Mr. Green this has been great following your adventure. 2012 Vogue 4.4 TDV8 - Current
Post #634259 10th Jun 2022 12:23pm
dhallworth
Cams have arrived.
I then went out to the workshop and got one of the new heads off the shelf.
I swapped the buckets over from the old heads after giving them all a good clean and gave the bearings a good coat of assembly lube before installing the first cam.
The cam bearings were then torqued in sequence to 10nm (7lbft
I then dug the feeler gauges and started measuring the clearances and noting them down on a template I’d made and printed.
On cylinder 7 and 8 I could only get a 6 thou feeler gauge in when clearance should be between 9 and 10 thou so I’ve done the sums and worked out for those 2 cylinders I need a 3.070mm and 3.175mm bucket.
Will finish the rest of them tomorrow now Smile
Post #634299 10th Jun 2022 7:24pm
Ooooh, nice shiny new bits.... glad they arrived OK Thumbs Up Pete
Post #634300 10th Jun 2022 7:36pm
