Home > My Range Rover > Back with another Supercharged
Page 34 of 58 <123 ... 333435 ... 565758>
dhallworth
Thanks Smile
I think there's about 8 I can reuse. I'm still not happy with it even after doing all the sums though. Am mulling over my options at the moment. I can spend £250 on tappets and find that the clearances aren't right and then start having to buy more or I can let someone who knows what they're doing set the clearances for me.
I'm leaning more towards letting someone who knows what they're doing set them. The place I bought the cams from has done extensive work on these engines and has an "Extensive" selection of buckets in stock so I'm thinking of taking them down to him to do.
Post #634750 15th Jun 2022 11:36pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I would let them do it.
It’s an unbelievable amount of work if you put it all back together and it’s not quite right on start up 😱
Post #634752 16th Jun 2022 7:02am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Dave,
you are a talented chap and clearly know your way around a car. However sometimes some jobs are best left to a specialist and in this case i would be opting to get them to do it. You have ploughed so much time, effort & expense into this project it would be a shame if this part was not correct and from what i see if it is not perfect you will not be happy and will not rest until it is. just my opinion Thumbs Up 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #634754 16th Jun 2022 7:57am
MonteCarlo
great work David, this thread is half the reason I don't own an L322 Laughing
Kudos to the dedication Mr. Green MY2001 Range Rover P38 Vogue 4.6
MY2005 Jaguar S type 3.0 SE
MY2000 Land Rover Discovery II TD5
MY1987 Bentley Turbo R "project"
MY1977 Rolls Royce Silver shadow. "project"
Post #634807 16th Jun 2022 9:27pm
dhallworth
Whilst waiting for the L322 valve clearances to get done it’s the P38 that’s had some tinkering. I replaced the steering box on that last night with one that I’d had rebuilt and am putting a new front caliper on it tomorrow evening. Smile
Post #634810 16th Jun 2022 11:14pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
For me this thread is an inspiration and the reason I am not worried about L322 ownership, David has proved that anything can be done by the home mechanic if you put your mind to it.
Thanks David and keep informing us of your work. Bow down Bow down
David
PS I really hope I never have to do the amount of work that David has done !! Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #634815 17th Jun 2022 1:31am
dhallworth
I've done a huge amount of "Whist I'm in there" work. This car didn't need a lot of the work I've done to it but I don't want to be taking things apart to get to things again in the future.
Post #634828 17th Jun 2022 12:25pm
Is it going OK Dave, it's been quiet on here...? Pete
Post #635268 23rd Jun 2022 11:50am
dhallworth
All good thanks, Pete. No progress on the Range Rover though. I'm sending the heads down to get the valve clearances set up properly so am just waiting for the guy who is doing it to confirm his availability.
Probably going to be another couple of weeks before I get them back and can start reassembly unfortunately Sad
Post #635269 23rd Jun 2022 12:00pm
Sandyt
Good move David I mucked about replacing a head gasket on a DB6 many years ago because I couldn't afford to get it done and ended up with an engine that sounded like a bag of spanners being rattled
Anyway I have rust on mine first time so will have to do that cant remember if you replaced the sills or not ?
Post #635307 23rd Jun 2022 9:18pm
dhallworth
Evening Sandy,
I’ve not got as far as removing the cills yet. Thankfully nothing in the rear door shuts or the cills you can see from underneath Smile
There was a lot of surface scale underneath it that I’ve spent a lot of time on but haven’t had to go any further. Yet. Wink
Post #635312 23rd Jun 2022 10:18pm
Sandyt
Mine is going in after our September France trip told them just do whatever is necessary so we shall see.
Post #635642 28th Jun 2022 1:36pm
dhallworth
Seeing as there's been nothing done on the car for a while I thought I'd do something useful with it last night...
The final part of the LPG puzzle was removed last night.
The engine is still in bits and the battery disconnected so I used the emergency tailgate opening procedure and then removed the LPG tank. It's being collected by it's new owner on Thursday evening along with the rest of the kit.
The boot floor has surface rust on it presumably due to moisture getting in from the additional holes that were drilled for the LPG.
First step is going to be hoover it out, probably this evening. I'm then going to chip away the surface rust (not using a wire brush on the grinder inside the car for obvious reasons) and then I'll coat it with Bilt Hamber Deox Gel and leave that for 2hrs before washing it off. I'm then going to order some more Bilt Hamber Epoxy Mastic to paint the inside of the wheel well with too.
Here's what I'm starting with:
All the air suspension parts at the front will be tidied up when I reinstate the compressor properly too.
I've been trying to decide what to do with the holes in the floor. I've considered cutting some steel to the right size/shape and welding them in, considered fibre glass to patch them, and I've also given thought to rubber bungs/grommets.
Seeing as from the factory the car already had grommets in the boot floor, I reckon this is the easiest/most effective way of sorting them out. It also means that if the tailgate seal ever lets go and starts to fill the spare wheel well with water it's easy to pop them out and drain it.
Post #635644 28th Jun 2022 2:08pm
Sandyt
When I removed the doughnut from the p38 I put grommets in and masticed them in been there for 15 years and all good
Post #635646 28th Jun 2022 3:01pm
dhallworth
Cheers Sandy, sounds like that's the way forward then Very Happy 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #635655 28th Jun 2022 5:02pm
