Home > Maintenance & Mods (L322) > Front door external window metal trim replacement (How To ?)
Page 2 of 3 <123>
ergobyte
France 2012 Range Rover Vogue 4.4 V8 Java Black
I'll make picture of the (winning) procedure for all to see !! "it needs some intelligence to undestand you may not have enough"
Post #634586 14th Jun 2022 9:51am
Googs
Australia
It’s hard to believe that no one else on this form has removed any parts like this before, good luck 🤞
Post #634660 15th Jun 2022 2:27am
ergobyte
especially if they rust, I can't believe i'm the only one... that would be such bad luck Big Cry "it needs some intelligence to undestand you may not have enough"
Post #634732 15th Jun 2022 8:47pm
Googs
Australia
Can you post photo of the affected one on your RR ?
Post #634733 15th Jun 2022 8:58pm
ergobyte
will get a picture tomorow at sun up (I mean when I'll wake up...) ! "it needs some intelligence to undestand you may not have enough"
Post #634734 15th Jun 2022 8:59pm
Googs
Australia
Ok, that will be good….help me understand exactly where they are supposed to fit.
What model RR ?
Post #634735 15th Jun 2022 9:03pm
It's the exterior black frame at the top of the doors, the early ones like yours didn't rust as much as the later ones, my 2002 was mint, my 2012 was rusty...!!! Rolling Eyes Pete
Post #634742 15th Jun 2022 9:52pm
Googs
Australia
Ok Pete thanks.
You have me curious about the trims….i just finished painting my Vogue and can’t recall any trims like that. I striped the doors down completely before prepping them too, must need better glasses. 🤣
Post #634743 15th Jun 2022 10:00pm
ergobyte
Here are the close-ups
it's the same on the front door opposite.
It could be disregarded, but ... I just hate it Evil or Very Mad "it needs some intelligence to undestand you may not have enough"
Post #634768 16th Jun 2022 10:46am
JCW
I wonder if you could carefully mask it off & re-paint in situ?
Post #634769 16th Jun 2022 10:49am
Googs
Australia
I can see the problem….steering wheel on wrong side🤣🤣.
Nah just joking, yes you could easily rub down with 3m 600 grit w/d paper and mask up…put semi-gloss paint on as JCW said.
Post #634772 16th Jun 2022 11:35am
ergobyte
I know, but
- I'd need the exact same satin finish black...
- it wouldn't get rid of the rust under, would it?
- it would be bound to resurface.
and lastly ... not at all compliant with my OCD mindset Rolling Eyes I know !
As for the wheel side, it is indeed shocking on a british car, yet so much more practical to use on the right side of the road (pun intended) Rolling with laughter [/list] "it needs some intelligence to undestand you may not have enough"
Post #634774 16th Jun 2022 12:04pm
IMHO waste of time trying to repaint that, the corrosion is coming from the back, around to the front, unless you took them off and got all the corrosion front and back off you are flogging a dead fatty, it will come back straight away... Thumbs Up
Some people put wind deflectors on which adhere to that part and cover up the unsightly corrosion... Whistle Pete
Post #634779 16th Jun 2022 12:58pm
ergobyte
Nah,
I can't cover it up and forget about it...
It just wouldn't right !
(with the voice of Ms Patmore from downton abbey) "it needs some intelligence to undestand you may not have enough"
Post #634784 16th Jun 2022 2:13pm
Out of sight, out of mind...lol.... Laughing
Anyway have you got the old one off yet..??
Any clues on the new one apart from those clips low down, does the top part have any fixings..?? Pete
Post #634785 16th Jun 2022 2:28pm
Page 2 of 3 <123>
