Home > Maintenance & Mods (L322) > H8 Bulb - Side Lights out ...confused... |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 374 |
Hi all
16th Jun 2022 9:19pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1348 |
I can see the front side lights have been changed to LED.
16th Jun 2022 11:45pm |
Thanks for your replies - Yes, you're right they have been changed before my ownership. I'll swap them out for original spec Gavin
17th Jun 2022 7:44am |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 118 |
No need to go back to the old bulbs cos LEDs are far better. Its the cold monitoring of the bulbs that throws up the error because the LEDs don't offer the same resistance as a normal bulb so thge system thinks the bulb has popped. If you've got an IID you can turn off the cold monitoring which will stop the error messages. The only drawback is you'll have to go back to the good old days and do a walk around check of your lights every now and then to confirm they are all still working. |
17th Jun 2022 7:18pm |
Thanks for all your replies. I took out the sidelight bulbs and they were indeed LED -
23rd Jun 2022 12:37pm |
Duplicate Post Gavin
23rd Jun 2022 12:44pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
If you want to use led bulbs buy good quality canbus error free bulbs and you won’t have any bother.
23rd Jun 2022 2:33pm |
Agreed. To be honest, just ditch the idea of any LED exterior lighting because the car's CANBUS system is so sensitive, even high end error free bulbs will cause errors sometimes.
23rd Jun 2022 6:02pm |
