Home > Maintenance & Mods (L322) > H8 Bulb - Side Lights out ...confused...
Superspoons
Hi all
I hope someone can help me here because I'm a bit stumped.
When I'm driving and have my side lights on I kept getting the 'Check Side Lights' and bong on the dash. Tonight I decided to whip the lights out and just look at/change the bulb if necessary - 5 minute job.....
But.... In the sidelight enclosure of the headlights there are two bulbs. One a simple bayonet which is working when on sidelights and another - an H8 Osram 12V 35W.
H8 -
The picture below shows the drivers (Uk) Headlight unit and the picture below that the non working H8 which is above the working bulb (bottom left of unit) -
I've ran a meter across both bulbs and both are fine so its not the bulbs themselves. My handbook makes no mention of this type of bulb and the pictures within it show back covers that flip off to reveal the bulbs, not unscrew like mine. In short, nothing like my headlight units. I'm 99% these are the original items for my 2006 model year XBC501392LPO -
Can anyone shed some light on what they do and what they should come on with ? Or are they a non used cornering lamp as I couldn't see any motors in there?
Thanks Gavin
1998 Defender 50th Anniversary - GB168 - preparing for sale
Post #634806 16th Jun 2022 9:19pm
Phoenix
The H8 is a static cornering lamp, they come on dependent upon the road speed and steering angle.
Are the rear side lights OK? have you changed any lamps for LED's?
Post #634808 16th Jun 2022 9:45pm
garyRR
I can see the front side lights have been changed to LED.
This is your problem. It's near impossible to get the L322 to accept LEDs (trust me, I tried on my 2006) if not originally designed for them. It throws up all sorts of errors, even if the bulbs claim they're error free.
Change back to halogen bulbs and it will fix your problem. 2015 Range Rover Autobiography 4.4 SDV8
Post #634813 16th Jun 2022 11:45pm
Superspoons
Thanks for your replies - Yes, you're right they have been changed before my ownership. I'll swap them out for original spec Thumbs Up Gavin
Post #634819 17th Jun 2022 7:44am
NobbyC
United Kingdom 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
No need to go back to the old bulbs cos LEDs are far better. Its the cold monitoring of the bulbs that throws up the error because the LEDs don't offer the same resistance as a normal bulb so thge system thinks the bulb has popped. If you've got an IID you can turn off the cold monitoring which will stop the error messages. The only drawback is you'll have to go back to the good old days and do a walk around check of your lights every now and then to confirm they are all still working.
Post #634878 17th Jun 2022 7:18pm
Superspoons
Thanks for all your replies. I took out the sidelight bulbs and they were indeed LED -
I had a packet of these standard Bosch bulbs handy so just fitted these for now. No error messages for now but I will look in to turning off the warning messages via the IID Tool.
Thumbs Up Gavin
Post #635273 23rd Jun 2022 12:37pm
Superspoons
Duplicate Post Gavin
Post #635275 23rd Jun 2022 12:44pm
If you want to use led bulbs buy good quality canbus error free bulbs and you won’t have any bother.
A word of warning, most if not all, of the so called canbus error free bulbs on the likes of eBay are absolute rubbish and will only work for a short time before causing issues.
You get what you pay for.
Post #635281 23rd Jun 2022 2:33pm
garyRR
Agreed. To be honest, just ditch the idea of any LED exterior lighting because the car's CANBUS system is so sensitive, even high end error free bulbs will cause errors sometimes.
Interior is fine though and I did a guide on how to replace all of the interior lights with high end LED upgrades. 2015 Range Rover Autobiography 4.4 SDV8
Post #635293 23rd Jun 2022 6:02pm
