Home > My Range Rover > And here it is… L322 Overland Build
Page 4 of 4 <1234
Bloke
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Have a sub. Thumbs Up
Post #634883 17th Jun 2022 9:28pm
2010BlackL322
United Kingdom 2010 Range Rover Autobiography Black 4.4 V8 Santorini Black
Thumbs Up Check out my YouTube channel
https://youtu.be/UHBbLWZXw4A
Post #634884 17th Jun 2022 9:30pm
Ajmngn
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Still avidly following on YouTube, please keep it up! Also struck me when you did initial install of Garmin Tread, they should add CarPlay as an app as there’s loads of aftermarket CarPlay ‘tablets’ just like the Garmin and it’s probably the best thing they could do for that device to make CarPlay accessible to all!
Anyway, I’m really interested in your tyre choice and feedback on fitting the 275 Cooper AT3 Sports 2s as am considering a set myself:
- seen lots of other forum members with 275/50/20 experience rubbing and also fouling on suspension struts. Have you had no issues?
- have you added any extra lift with IID or your lift tool to raise the ‘standard’ ride height?
- what have you done as a spare tyre solution?
- what settings did you use in your CCF file when adjusting for the larger tyre?
Very many thanks in advance and keep up the great content! 👍 Andy
2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior
2017 Audi SQ5 3.0 V6T Quattro in Volcano Red
2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green (Currently SORN whilst undergoing some serious restoration!)
Post #637055 16th Jul 2022 11:14pm
2010BlackL322
Thanks.
The rear filler tube on the OSR has worn away, but I knew that would happen. On opposite lock, the OSF does rub. No rubbing anywhere else. I’m running L405 1065 rims, which do have a better offset that fills the arches, which I think helps remove some rubbing.
I have an Easylift, not touched the IID for that, I run standard heights, but use the Easylift when offroad which adds +2 extr travel beyond extended height.
I run a 20” L405 space saver wheel and rim, in the boot.
haven’t touched it, and from the GPS Tread, doesn’t seem to be that much out from the speedo +/- 1/2 a mile, that’s seems to be all.
Hope that helps
👍🏻 Check out my YouTube channel
Post #637057 17th Jul 2022 12:04am
Page 4 of 4 <1234
