![]() | Home > Maintenance & Mods (L322) > Juddering and shaking at WOT |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8793 ![]() ![]() ![]() |
Sounds low to me but I have no idea what it should be... |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3327 ![]() ![]() ![]() |
Idle is about right from memory. Not sure what it should be at wide open throttle though.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2250 ![]() ![]() ![]() |
Interesting I’m just sat here with key in pos 2 and rail pressure is now 520 Current stable:
Also looking through the data I am getting misfires at high rpm mainly in cylinder 5 - 7 and a couple in 1 -1I doubt it will be plugs or coils as they are less than 10k old - only issues when hard driving as mentioned Current stable:
I’m wondering if it stinks when you’re pushing it because it’s running lean and getting hot.
Snapon says that’s at 5000rpm which was at 89% load - and it’s open loop due to demand - it didn’t get any higher - the manual says 550kpa is the operating pressure of the pump I guess I need to work out is the pump causing the restriction or something else…? Current stable: 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
What’s really interesting in from stinking of sulphur like the cats were getting hot and stinking since sorting the T I now get the opposite smell like the cats not working as it smells a bit rich. As the misfires are all bank 1 and that’s the one I put the second hand cat on last year… do these sound like potential cat issues? Or fuel pump? Cheers as always! Current stable: 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
My money is still on the filter but that is just a guess.... |
You might be right I don’t get why it can hold the correct pressure thought when not running if it was the filter, the filter is one of these filter for life in tank jobs I changed it about 10k ago i guess it could be bad bad the intakes for the pump have gauzes on them too Current stable:
If you changed it that recently then that rules it out I recon...
Ok, I cracked the rear o2 on the bank with the misfire (1) let it cool down for an hour and put my scope in the hole… I think this cat looks ok? Looks like some of they honeycomb has bits in but guess that’s ok?
It might be your camera but the innards of your cat are incredibly white. Every other car I’ve seen, my SC included the innards of the cats are much darker. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
I had to have the flash light on full brightness so I assume it’s just reflecting? I’m guessing colour wouldn’t cause a problem but may suggest one ? Current stable:
When things get white it usually means they’ve been very hot. Running lean creates heat so could it be that it’s lean? I’m really not sure tbh. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
