Home > Maintenance & Mods (L322) > Juddering and shaking at WOT
Page 2 of 4 <1234>
Danwilderspin
Right I disconnected the return altogether and just run in petrol.
Did the same so I plugged in my snapon I get max 427kpa fuel rail pressure when it does it and I’m flat out - and it’s idles around 300kpa - does that sound about right or not?
Trying to work out if I can put the pump back together and work somewhere else or if I found the issue Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #635203 22nd Jun 2022 7:29pm
Sounds low to me but I have no idea what it should be... Thumbs Up Pete
-Click here for Thread-
Post #635204 22nd Jun 2022 7:38pm
dhallworth
Idle is about right from memory. Not sure what it should be at wide open throttle though.
Post #635208 22nd Jun 2022 7:49pm
Danwilderspin
Interesting I’m just sat here with key in pos 2 and rail pressure is now 520 Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #635210 22nd Jun 2022 7:52pm
Danwilderspin
Also looking through the data I am getting misfires at high rpm mainly in cylinder 5 - 7 and a couple in 1 -1I doubt it will be plugs or coils as they are less than 10k old - only issues when hard driving as mentioned Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #635211 22nd Jun 2022 7:53pm
dhallworth
I’m wondering if it stinks when you’re pushing it because it’s running lean and getting hot.
There’s no way the fuel pressure should drop at wide open throttle. At wide open throttle these things are using a huge amount of fuel so if the pressures dropping and it’s stuttering/hesitating then I’d say it’s definitely fuel pressure related.
The pressure regulator on these is built into the pump I believe as is the filter so I think I’d be having a look inside the tank next if I were you.
Post #635212 22nd Jun 2022 7:55pm
Danwilderspin
Snapon says that’s at 5000rpm which was at 89% load - and it’s open loop due to demand - it didn’t get any higher - the manual says 550kpa is the operating pressure of the pump I guess I need to work out is the pump causing the restriction or something else…? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #635213 22nd Jun 2022 7:56pm
Danwilderspin
David.
What’s really interesting in from stinking of sulphur like the cats were getting hot and stinking since sorting the T I now get the opposite smell like the cats not working as it smells a bit rich.
As the misfires are all bank 1 and that’s the one I put the second hand cat on last year… do these sound like potential cat issues? Or fuel pump?
Cheers as always! Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #635214 22nd Jun 2022 8:02pm
My money is still on the filter but that is just a guess.... Rolling Eyes Pete
Post #635215 22nd Jun 2022 8:14pm
Danwilderspin
You might be right I don’t get why it can hold the correct pressure thought when not running if it was the filter, the filter is one of these filter for life in tank jobs I changed it about 10k ago i guess it could be bad bad the intakes for the pump have gauzes on them too Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #635216 22nd Jun 2022 8:18pm
If you changed it that recently then that rules it out I recon...
Not a clue in that case, sorry.... Pete
Post #635221 22nd Jun 2022 8:58pm
Danwilderspin
Ok, I cracked the rear o2 on the bank with the misfire (1) let it cool down for an hour and put my scope in the hole… I think this cat looks ok? Looks like some of they honeycomb has bits in but guess that’s ok?
If the consensus is yes the only thing I can try is to clean the filter - on the other Range Rover site they reckon you can do this with the filter on these cars ( should be fairly clean due to age anyway) and then I’ve got that two year old fuel pump with the failed jet unit so I may try and fit that at lunchtime at the same time as I’ve left everything open except the hole to the tank…
Any other ideas?
Also the plug in the picture is 12 months old not sure if it’s relevant but I thought I’d post a pic 😀
 Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #635228 22nd Jun 2022 9:56pm
dhallworth
It might be your camera but the innards of your cat are incredibly white. Every other car I’ve seen, my SC included the innards of the cats are much darker. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #635232 22nd Jun 2022 10:36pm
Danwilderspin
I had to have the flash light on full brightness so I assume it’s just reflecting? I’m guessing colour wouldn’t cause a problem but may suggest one ? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #635233 22nd Jun 2022 11:11pm
dhallworth
When things get white it usually means they’ve been very hot. Running lean creates heat so could it be that it’s lean? I’m really not sure tbh. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #635236 22nd Jun 2022 11:19pm
Page 2 of 4 <1234>
