Home > Maintenance & Mods (L322) > Air Con problem
DrRob
4.4 TDV8 A/C compressors seem to be service item Rolling with laughter Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #639182 10th Aug 2022 1:34pm
kevinp
Well Rob, got in the car this morning all excited for a cold ride and it's at best just cool again!! Censored Censored
Post #639267 11th Aug 2022 9:28am
garyRR
Depending on how the control valve is behaving, you'll get different symptoms. At the end of the day, the valve is basically a solenoid. It restricts flow into the evaporator. It can trap on either side of the system. 2015 Range Rover Autobiography 4.4 SDV8
Post #639270 11th Aug 2022 9:39am
JayGee
The symptoms ‘are’ random functionality - one day it’s working and the next it can be pumping out hot air. Wanted mine fixed just for the summer holiday but also for winter where it’s necessary for demisting and dehumidifying. 2012 TDV8 Vogue (L322)
Post #639277 11th Aug 2022 10:48am
kevinp
Yes. Just been out in it again and it's working.
Post #639285 11th Aug 2022 11:32am
mjdronfield
New compressor mate.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #639309 11th Aug 2022 4:52pm
Old-un
United Kingdom 2011 Range Rover Vogue 4.4 V8 Causeway Grey
My garage tells me via text that I am due an 'air con service'
What should this entail and how much about should it cost by non main dealer ? RR owner
Post #693052 21st May 2024 10:05am
PeteT80
If it’s working and blowing cold then I wouldn’t bother.
Post #693053 21st May 2024 10:17am
