Home > My Range Rover > My 2011 Range Rover L322 4.4 TDV8 Vogue SE story
Page 3 of 4 <1234>
JayGee
If it's ''bouncy' that would indicate shocks are worn out. The adaptive dynamics system fails safe so the shocks go to full stiffness when there is no electrical signal going to them. 2012 TDV8 Vogue (L322)
Post #640304 20th Aug 2022 4:20pm
Good to know, thanks... Thumbs Up Pete
-Click here for Thread-
Post #640306 20th Aug 2022 4:35pm
Note to self.....
Always take a ladder to buy a Rangie.... Rolling with laughter
I moved it down the drive this morning and the drive is lower than the path... even me at 6ft5 couldn't see this from the level...
No rust so it's just the colour and clear coat...
A trip to the bodyshop in order , he will moan like Censored as he hates painting roofs Laughing Pete
Post #640490 22nd Aug 2022 11:50am
JayGee
WTF Shocked 2012 TDV8 Vogue (L322)
Post #640491 22nd Aug 2022 11:52am
johnboyairey
well Pete, even the wise are sometimes 'had' !!
im thinking that from the paint finish, its already had some repair work, and that has failed, and peeled off, possibly hail damage, or tree branch drop. might be worth cleaning the roof up well, to see if there are any clues as to how much was repaired.
-maybe the sprayers' arms weren't long enough to cover the base colour with enough clear coat?
or, a seagull ate a vindaloo!
Post #640494 22nd Aug 2022 12:24pm
I don't think I was had, the guy I got it from was shorter than me and who looks up there...
Yep, the centre panel of the roof has been sprayed before, I've had a good look over it and can't find any sinkage or tell tale sanding marks, just the orange peel paint... looks like it was done years ago when it was young... the roofbar covers are still there with no marks around them...
It shall remain a mystery, personally I like the seagull scenario.... Laughing
I shall get this fatty sorted mechanically and run it for a bit to check it's not a Friday car, it's got FSH but there are some deferred maintenance issues that need sorting. Then it can have some TLC on paint/trim etc.... Pete
Post #640497 22nd Aug 2022 12:45pm
A bit of garage time today... Fatty nestling in it's native habitat.... Rolling with laughter
Mine "supposedly" had a recent service, this is why I always service cars when I buy them, I mean you just can't make this up...
Passenger side on the left, drivers on the right....
So they changed the one that takes the longest, the passenger side, as you have to remove the glowplug relays....
You have to wonder what else they didn't do...
Front airbag replaced as well, found the front outer driveshaft boot damaged, looks a recent failure so add that to the list...
Checked the aircon,
476g recovered
700g refilled, nice and chilly now...
Getting there though, was a pleasant drive home....
This colour is stunning when the sun hits it...
Pleased to be back in one.... Thumbs Up Pete
Post #640652 23rd Aug 2022 7:26pm
JayGee
Passenger side airbox only feeds the 2nd stage turbo so hardly gets any use and hence why it's never changed as part of a normal service - it may even be the original one fitted at the factory. 2012 TDV8 Vogue (L322)
Post #640653 23rd Aug 2022 7:30pm
It was the passenger side that was new...!!! Pete
Post #640655 23rd Aug 2022 8:03pm
JayGee
Date stamped newer than the driver side or just cleaner than the driver side? 2012 TDV8 Vogue (L322)
Post #640656 23rd Aug 2022 8:13pm
mjdronfield
As the passenger side hardly gets used, it’s not inconceivable that both were changed at the same time…. Though obviously not that recently. Both of them being the same brand could back the theory up….. ?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #640657 23rd Aug 2022 8:13pm
As I said, it was "supposed" to have just been serviced, the passenger one looks new, the drivers side far from it. it just looks like they changed the wrong one....
Not to worry they are both new now, as is the pollen, fuel, oil and oil filter.... just for starters.... Thumbs Up Pete
Post #640660 23rd Aug 2022 8:37pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Welcome to the dark side Haylands Thumbs Up
She looks gorgeous when the sun catches her, for sure! Shame about the roof mind…
Those rear shocks sound shot. One of mine went and the rear bounced like you describe, but was a simple change only taking an incomplete me a few hours.
Good luck and look forwards to the updates Thumbs Up Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #640690 24th Aug 2022 6:58am
Few more jobs done,
Replaced both rear dampers with genuine Bilstein CVD ones, it's composure has returned and it now feels very planted...
Changed the front off side outer CV boot, it was a right pain, the shaft would not come out of the hub, I know a guy who has a puller for it but forgot to ask before and he wasn't around so....
Took the whole front hub off complete with the full driveshaft, stuck it in the vice and got the shaft out the CV, changed the boot for a GKN one and filled it up with new grease...
The longest part was cleaning all the grease of everything...!!!
Rear view camera taken apart and reassembled properly, great help from some guys on here on my other thread. gone form this
To this, which is good enough to reverse by...
A new one for the uprated vision assist pack is LR031812 about £350 from Dan... Shocked
It's now driving nicely but still more I want to do.... Thumbs Up Pete
Post #641904 3rd Sep 2022 8:12pm
dhallworth
Looking good, Pete!
How are you finding the oil burner in comparison to the SC?
Post #641913 3rd Sep 2022 9:57pm
Page 3 of 4 <1234>
