Home > Technical (L322) > Reduced performance DPF filter full.
Page 3 of 5 <12345>
SETDV8
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Kevinp and Jay Gee, I've got my glad rags on now so will have a look tomorrow.
Thanks both for the suggestions.
Post #640315 20th Aug 2022 4:54pm
garyRR
SETDV8 wrote:
Just when I thought it was sorted!!!!!
Just did around 50 miles in reduced performance mode AGAIN!! 80% of the journey was motorway, as I accelerated in the outside lane there was a sudden shudder and reduced performance mode kicked in straight away, within 2 miles DPF Full waves hello at me closely followed by the engine management light!
On my return home I removed the plastic engine cover to find little oily deposits in various places across the top and towards the front of the engine, see photos attached.
It's back to the garage on Monday.
Anybody ever experienced this before?
I'm seriously hacked off and am starting to regret buying the bloody thing!!
Fed up,
Steve.
Don't worry. You've clearly just got a leak in the intake system somewhere. None of these parts are expensive.
I'd be looking at the left charged air hose to the intercooler and also the plastic union with the metal spring clip - both are in this vicinity. 2015 Range Rover Autobiography 4.4 SDV8
Post #640325 20th Aug 2022 6:03pm
SETDV8
Thanks Gary, hope you're right.
Post #640367 21st Aug 2022 9:52am
SETDV8
Update from today.
Turns out that the nearside inlet manifold has split at its seam.
Thankfully the dealer I bought it from has agreed to cover the full cost of replacement under their own warranty. Only issue now is that a replacement manifold is on back order, could be a week or up to a month.
For the time being I am the proud driver of my mates 241000 mile 2007 Toyota Prius, reliable though Very Happy
Cheers,
Steve.
Post #640556 22nd Aug 2022 9:58pm
DrRob
It did hint at a split manifold from your original symptoms....hope you get one delivered soon Thumbs Up
There will always be issues with a "new to you" vehicle. All been there. Once sorted it's then a case of preventative maintenance. That's served me well over the years Bow down Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #640567 23rd Aug 2022 6:21am
kevinp
There's one on ebay, but in Lithuania if you need it 'quicker'.
Maltings have one with next day delivery.
Post #640575 23rd Aug 2022 7:38am
SETDV8
Thanks Rob, I take your point.
Kevin, thanks for the heads up re the part but I think my garage have ordered it from Land Rover. I'm popping in to them this morning so will find out.
Cheers
Steve.
Post #640580 23rd Aug 2022 8:17am
garyRR
I'm pretty confident they're regularly in stock. I may be kidding myself but I think I saw Maltings had 2 last week which are sold now. Probably just a case of waiting a week or two for the next warehouse delivery. I'm not sure where they're made or who makes them for Land Rover.
In terms of the labour when it arrives - it can probably be done whilst you wait. There's only around 40 minutes to an hour of work, mostly undoing and refitting all the hoses 2015 Range Rover Autobiography 4.4 SDV8
Post #640581 23rd Aug 2022 8:21am
SETDV8
Cheers Gary Thumbs Up
Post #640582 23rd Aug 2022 8:24am
kevinp
Gary, you thinking of the plenum chamber and not the inlet manifold? Doubt you could do the inlet manifold in that time.
Post #640583 23rd Aug 2022 8:53am
garyRR
Definitely the inlet manifold. It's not overly difficult. To remove and replace when you've done a few before. 2015 Range Rover Autobiography 4.4 SDV8
Post #640584 23rd Aug 2022 8:55am
kevinp
That's fair enough mate. Think it took me longer than that to just take the plenum off!! I suppose if you've done it once then it is quicker next time.
Post #640594 23rd Aug 2022 10:17am
garyRR
Plenum is 2 minutes when you've done it umpteen times 😉 2015 Range Rover Autobiography 4.4 SDV8
Post #640595 23rd Aug 2022 10:34am
DrRob
Sounds like it takes a lot shorter time to do the inlet manifolds on a 4.4 tdv8 than a 3.6? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #640597 23rd Aug 2022 10:40am
JayGee
They can be repaired by a line of rivets or self tapping screws along the seam. 2012 TDV8 Vogue (L322)
Post #640607 23rd Aug 2022 11:59am
Page 3 of 5 <12345>
