Home > Technical (L405) > 2013 RR L405 Autobiography with Odd Issues |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 |
Might be worth disconnecting the battery positive and negative leads for 10 minutes (minimum) then touching the positive and negative leads together for 30 seconds and reconnect them to the battery. This will carry out a reset of the ECU's and might resolve the issue for you. 2011 TDV8 Vogue SE |
9th Sep 2021 4:02pm |
KarlC Member Since: 23 Feb 2017 Location: San Diego Posts: 11 |
That's a thought, could the reset casue any issues ?
9th Sep 2021 4:12pm |
You'll lose the time/date and any other personal settings you may have such as one touch windows and radios stations etc. Do you have a secondary battery in the boot/trunk? 2011 TDV8 Vogue SE |
9th Sep 2021 4:29pm |
We don't really have any personal items set up so no worries there.
9th Sep 2021 4:43pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Check the voltage when the engine is running, should be around 14.5volts, Then check the battery voltage about 30 mins after switching off, then test again a day later and see how much the voltage has dropped, it could be a parasitic drain causing your problems. Pete
9th Sep 2021 5:58pm |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 219 |
The 2013 doesn’t have a secondary battery as there is start-stop. |
10th Sep 2021 3:30pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34916 |
to check to see if you do have an aux battery, look inside the rear right panel [as you stand at the back looking towards the front] ... - .- -.
10th Sep 2021 4:48pm |
As an update, I called IE Rovers .... https://www.facebook.com/IERovers/ ..... https://www.yelp.com/biz/ie-rovers-lake-elsinore ... late yesterday, they said bring it in 1st thing in the AM and we will have a look for you.
10th Sep 2021 5:55pm |
When I took it to the INDY IE Rovers , they ran a diagnostic. |
14th Sep 2021 9:38pm |
Thx all for your input.
25th Aug 2022 1:17am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
That’s utter BS I’m afraid sir… Only MD can look at your can system 🙄
25th Aug 2022 8:55am |
What he said..... Pete
I assume the battery wiring is nice and snug? (Tight for us brits 😏) |
25th Aug 2022 8:57am |
Thank you for the input guys. Thanks for your help . Last edited by KarlC on 7th May 2023 5:24pm. Edited 3 times in total |
25th Aug 2022 3:40pm |
