Home > Maintenance & Mods (L322) > Diesel virgin
Page 2 of 5 <12345>
DrRob
You can drive yourself bonkers analysing DPF regeneration workings....I've seen it on here a lot Rolling with laughter
Make sure your inlet hoses are upgraded from the stock rubbish Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #640387 21st Aug 2022 2:55pm
Baltic Blue
I understand Pete’s desire to understand the procedure.
I am exactly the same and put it down to my engineering brain being trained to work out how things work so I know how to fix anything when it breaks . Rolling with laughter
Post #640391 21st Aug 2022 3:04pm
I don't fret or worry about cars, just nice to know what makes them tick... everything is repairable, some faults just cost more knuckles than others.... Rolling with laughter
Inlet hoses are on the list, pretty near the top as well.... Thumbs Up Pete
-Click here for Thread-
Post #640392 21st Aug 2022 3:06pm
Baltic Blue
Get a supply of disposable gloves because you are about to discover just how dirty modern diesels really are.
Also clean the MAPT sensor whilst you have the bonnet up. It’s a five minute job, but a well known cause of R.P. bongs when clogged up.
Post #640394 21st Aug 2022 3:39pm
Cheers.... Thumbs Up Pete
Post #640397 21st Aug 2022 4:18pm
ergobyte
France 2012 Range Rover Vogue 4.4 V8 Java Black
HI Pete,
I bought my 2012 4.4 TDV8 vogue in oct 2021 with 160000 km and supposedly nothing to do, from a reseller.
took a warranty though Wink
since I had the oil filter radiator (a classic gasket failure), a rear air suspension replacement (right) and a recent (170000km) DIRECT TO RED ALERT limp mode "DPF filter full" EGR failure (that did cost me 3500 Euros, half of which was under warranty).
I'm like you I didn't know I had to monitor anything. Embarassed
Now I plan a 1/2h highway run every week or so... "When in Doubt, Do Something"
AND I'll get an ODBII reader... any recommendation for the brand and model ?
Cheers
Sylvain "it needs some intelligence to undestand you may not have enough"
Post #640863 25th Aug 2022 4:37pm
There will always be something to do, I regularly try out all areas of the rev range to give my cars the exercise they need... use it or lose it as they say....
I've always had the Gap IID tool, I find it does everything you want and a lot more besides, plus it's small and fits in the glove box no bother...
I'm reading all I can about the diesel to give me some understanding of how it works so I can, hopefully, get to the bottom of any issues... Thumbs Up Pete
Post #640867 25th Aug 2022 4:49pm
johnboyairey
my experience, was when I bought mine, as I left Birmingham to drive it to London, I got a red DPF alarm, (D'oh!) just as I was leaving the city, which on the motorway, I found I had restricted speed, around 50mph, and no real power. BUT after a 30 mile drive, I stopped, and after that it was driving fine. so it sort of fixed itself, a little. which goes against handbook theory. since then, and frequent dual carriageway and motorway drives, it never flagged anything up. however, about 8 months on, I got a yellow alarm, and that was in central London, and heavy traffic. and within 10 mins of idling, it went red. which I was annoyed about, as that is sort of 'don't drive it, get it to dealers'. so I got it home, again with a lack of power... and read the soot levels on the IID, I was now at 32grams. I had a code fault on my manifold, 'p0040d' which was not allowing 'on the road' type regens. (sensor was testing open circuit) so even with contstant cruising, it was sooting up. somewhat. anyway, I couldn't get the sensor out, as the nut broke off, and unable to get the new sensor to ever get hot...so had to make it think it had a hot temp, (sensor) with a DIY resistor. (650 ohms) I then took it out for a motorway cruise, and with the Iid tool, under service/test page, you can force a regen. you will see that the speed only needs to be 25mph, (reading goes from red to green) and temp at normal, and more than 1/4 tank of fuel. you can also see the soot level, and after about 15-20 mins, at about 40-50 mph, so I never hit any bunching traffic, it started to fall quite fast. and after a further 15 mins, was at around 0.3 gram. I then pulled off, stopped car, and dash warning was clear. car was perfect. left the resistor in, and car seems fine now, as can complete passive 'on the road' regens. p.s. you do not do Italian tune-up type 'thrash' driving, you need low revving cruise. I think you just need air blowing under the car, to stop the DPF overheating, whilst it cremates the soot.
note, each regen has an effect on the oil in the engine (so I understand) as some diesel fuel is introduced? so you have a page on the IID to monitor oil condition. interesting stuff. the IID tool read logs, that will tell you how many regens have ever happened, there will be hundreds of incomplete ones, and a handful of completed ones. (if its like mine, at 200k)
Post #640873 25th Aug 2022 5:24pm
John, thanks for that, I read your other posts about your sensor issue, very interesting and informative, I wasn't saying an Italian tune up is good for regens, it's good to keep things working and exercised in general...
The driving I do these days seams to be just what this engine needs, a mixture of roads from B roads to M roads... hopefully that will be good enough... Thumbs Up Pete
Post #640874 25th Aug 2022 5:59pm
JayGee
Never work mine hard and can go for months without going over 2krpm or activating the 2nd stage turbo. Never do short trips and only use it for long drives. Every time you apply the power unnecessarily it's straining components and shortening their life.
 2012 TDV8 Vogue (L322)
Post #640876 25th Aug 2022 6:16pm
Well we will have to agree to disagree. I firmly believe in exercising a vehicle to it's parameters as long as it is well serviced and thoroughly warm. Certainly not thrashing it and not all the time but using the vehicle to it's full extent is my preferred method... Each to their own... Thumbs Up Pete
Post #640894 25th Aug 2022 8:29pm
Kot
I agree use it or lose it. On everything. Whistle
I always everyday, make sure I get the 2nd Turbo to kick in. 2018 SE SDV8 4.4 Byron Blue
Post #640904 25th Aug 2022 9:30pm
DrRob
Agreed. Open the taps for that second turbo to clear its guts...I do it regularly once engine up to temp. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #640909 25th Aug 2022 9:44pm
JayGee
Can anyone explain by what physical process a mechanical system will last longer by subjecting it to more stress?
Should I drive faster, accelerate harder or for more miles to increase the lifespan of the engine, suspension, brakes etc……. 2012 TDV8 Vogue (L322)
Post #640910 25th Aug 2022 9:51pm
mjdronfield
I try and get my second turbo spinning once per journey to stop the oil building up in whatever pipe it sits in…. I don’t have the turbo drain mod….. it smoked a bit when I first got it, and that has stopped the issue.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #640913 25th Aug 2022 10:01pm
Page 2 of 5 <12345>
