![]() | Home > Maintenance & Mods (L322) > Diesel virgin |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3385 ![]() ![]() ![]() |
2012 TDV8 Vogue (L322) |
The egr cooler is designed to cool normal exhaust gas temperature but it's unlikely going to be able to reduce the highly raised EGT to the same level at regen. The regen process doesn't spew out soot as it's burnt ![]() |
This explains quite a bit
Hahaha, that doesn't explain anything, it's a theory from 1983 and a patent of some snake-oil from 2011 - neither of which are in current use.
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1434 ![]() ![]() |
.[/quote]
Well I learned something new |
It simply explains the basic chemical process inside a DPF for regeneration and is the same basic science I remember being taught way back at school. If that was ‘theory’ and snake oil can you update me with the current science for carbon combustion / DPF regeneration i.e what does it now produce (sorry ‘spew’) if it’s not CO2 and at what temperature does this happen? 2012 TDV8 Vogue (L322) |
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
"I just hope you never sell your car as some poor sod is going to have bought a real moneypit."
But it clearly says 600C in your article as well!! ![]() ![]() ![]() |
Yes 600 deg c is the temp you need to burn carbon cleanly as referenced by many articles. My comment you are quoting was in reference to Phoenix who seems to think it’s out dated or snake oil ( hint - the meaning is in th |
Your thoughts being that driving gently to not stress the drivetrain on a 150k mile car is bad ? Or is it the more frequent oil changes? Or avoiding short urban trips and only putting on motorway miles ? - or have I missed something? ![]() |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1413 ![]() ![]() |
Can you wait for a while?
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1361 ![]() ![]() ![]() |
Surely the parts of the drivetrain are designed for such use. If they break then mend them.
And if I wanted to prolong it's life and not have to spend money on or worry about replacing drivetrain parts ? Also the L322 feels just right wafting gently along. I'm not talking about driving like a slow road nuisance either as it gets up to speed very briskly without needing the 2nd turbo. Surly this is the very essence of the L322 - effortlessness progress in any situation |
