Home > Maintenance & Mods (L405) > Kick Plate Removal
batmanreturns
Kick Plate Removal
Hello, does anyone know how to remove the kick plates front and rear on the L405? Mine have seen better days and i want to replace them but can't find anything online, youtube etc. I would just give it a go but don't want to break anything. thanks
Post #640720 24th Aug 2022 10:22am
batmanreturns
nudge! anyone able to help? Can't find anything online or via youtube etc thanks
Post #641641 1st Sep 2022 10:56am
i believe they prise upwards.. ... - .- -.
Post #641643 1st Sep 2022 11:06am
batmanreturns
thanks, i think they do but it's the removal of the plastic trims that semi sit opn top of them, it looks like you need to remove these prior?
Post #641645 1st Sep 2022 12:04pm
batmanreturns
.....and if so how? thanks
Post #641646 1st Sep 2022 12:04pm
those bits that slightly cover the tread palates are just push fitted... ... - .- -.
Post #641654 1st Sep 2022 12:49pm
Pull the top of the lower half of the B pillar trim towards the seat using a trim tool, then when it's all popped off, lift it off the lower plastic B pillar cover... Then you can simply pull the lower foot-shaped panel upwards and it should just come out... Then you can see your sill panels and their wiring... The fronts are self-explanatory, the rears however may need the rear cover panel removed? This simply pulls towards the front of the car, with two fixing poppers Thumbs Up
Post #641765 2nd Sep 2022 10:41am
