![]() | Home > Maintenance & Mods (L405) > Kick Plate Removal |
| batmanreturns Member Since: 16 Jan 2017 Location: Wiltshire Posts: 67
nudge! anyone able to help? Can't find anything online or via youtube etc thanks |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
i believe they prise upwards.. ... - .- -.
thanks, i think they do but it's the removal of the plastic trims that semi sit opn top of them, it looks like you need to remove these prior? |
.....and if so how? thanks |
those bits that slightly cover the tread palates are just push fitted... ... - .- -.
Pull the top of the lower half of the B pillar trim towards the seat using a trim tool, then when it's all popped off, lift it off the lower plastic B pillar cover... Then you can simply pull the lower foot-shaped panel upwards and it should just come out... Then you can see your sill panels and their wiring... The fronts are self-explanatory, the rears however may need the rear cover panel removed? This simply pulls towards the front of the car, with two fixing poppers |
| All times are GMT |
