![]() | Home > My Range Rover > Back with another Supercharged |
| Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 408
Just catching up with the thread David after being away - the SC is looking great |
| Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601
lets hope and see you may just get lucky David!!
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3346
I’ve given the PCB a good scrub with some contact cleaner and a toothbrush and it now looks spotless. Didn’t have time to plug it in again this evening so will have another look at refitting it tomorrow evening.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Big fingers crossed emoji for you David |
Thanks Craig |
Did find one more job to do today though…
great stuff David everything is coming along nicely 2012 Vogue 4.4 TDV8 - Current
Thanks |
I have the same problem with my handbrake David - New shoes, springs & clips but not new cables though. Despite following the process and 'clicking back the adjuster' its a slack as a slack thing. Was fine when I set it so really odd.
Spoke to the specialist earlier today and he said he was snowed under and short of men this week so would appreciate me having a look at the handbrake if I could.
Fingers crossed for tomorrow David |
This one is the electronic parking brake, other then the adjusters on the shoes, there’s very little you can adjust on it.
Of course 2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics |
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
The park brake issue is probably the shoes binding on the backplate, I always used a cable tie to apply a bit of Nickel grease on the rubbing points and a screwdriver to pull the shoes away for access.
