![]() | Home > My Range Rover > Back with another Supercharged |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 401 ![]() ![]() ![]() |
Just catching up with the thread David after being away - the SC is looking great |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
lets hope and see you may just get lucky David!!
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3310 ![]() ![]() ![]() |
I’ve given the PCB a good scrub with some contact cleaner and a toothbrush and it now looks spotless. Didn’t have time to plug it in again this evening so will have another look at refitting it tomorrow evening.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Big fingers crossed emoji for you David |
Thanks Craig |
Did find one more job to do today though…
great stuff David everything is coming along nicely 2012 Vogue 4.4 TDV8 - Current
Thanks |
I have the same problem with my handbrake David - New shoes, springs & clips but not new cables though. Despite following the process and 'clicking back the adjuster' its a slack as a slack thing. Was fine when I set it so really odd.
Spoke to the specialist earlier today and he said he was snowed under and short of men this week so would appreciate me having a look at the handbrake if I could.
Fingers crossed for tomorrow David |
This one is the electronic parking brake, other then the adjusters on the shoes, there’s very little you can adjust on it.
Of course ![]() 2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics |
The park brake issue is probably the shoes binding on the backplate, I always used a cable tie to apply a bit of Nickel grease on the rubbing points and a screwdriver to pull the shoes away for access.
