Home > Technical (L322) > Aerosus front air springs |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
Yes, 8mm Allen key to hold and spanner to tighten. I literally cannot get it any tighter or I fear something will shear. Christian.
10th Sep 2022 2:11pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
I've just changed a front bag on mine and it has sealed with only a "normal" amount of torque on the top nut...
10th Sep 2022 4:33pm |
Opened a return to Aerosus now and ordered BWI bags, I cannot be dealing with this nonsense.
12th Sep 2022 6:00pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 |
That's quite a tight fit
12th Sep 2022 6:18pm |
When I removed the old ones they literally just fell off, this is another level!
12th Sep 2022 6:32pm |
Hopefully the bwi bags will give you a better result |
12th Sep 2022 6:37pm |
Still cannot get the airbag off, it's well stuck on there.
13th Sep 2022 9:05am |
Try clamping the top swivel section in the vice and striking the top of the strut, if you've not already done so |
13th Sep 2022 9:57am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2982 |
Could you use a big puller on the edges of the metal band around the air bag with the centre of it on the top of the strut?
13th Sep 2022 11:27am |
Tried everything and eventually had to cut the bags off.
22nd Sep 2022 9:31am |
