Home > Technical (L322) > Aerosus front air springs
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Yes, 8mm Allen key to hold and spanner to tighten. I literally cannot get it any tighter or I fear something will shear. Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #642594 10th Sep 2022 2:11pm
I've just changed a front bag on mine and it has sealed with only a "normal" amount of torque on the top nut...
I used an OEM bag and it has worked fine so if yours is still leaking from there it must be a faulty bag... Thumbs Up Pete
-Click here for Thread-
Post #642604 10th Sep 2022 4:33pm
Caesium
Opened a return to Aerosus now and ordered BWI bags, I cannot be dealing with this nonsense.
I also cannot get the bloody Aerosus bags off the strut now, they appear to be stuck on there. I think I;'m going to have to cut them open and then get the hammer on the underside of the swivel joint. I;ve never known anything like this.
I'm not convinced that Aerosus bags are fit for purpose.
 Christian.
Current Cars
2019 BMW X4
or
Post #642779 12th Sep 2022 6:00pm
dingg1
That's quite a tight fit Laughing
I ordered two aerosus bags, fitted ok, one failed after a day or so, the bag pulled from the top clamp creating a massive leak, in fairness aerosus replaced it with no requirement to return it, but removing it from the strut was quite easy tbh.
Just clamped it in the vice and knocked it round the circumference gradually using a piece of wood and a pound and a half hammer and it worked itself off fine
Post #642782 12th Sep 2022 6:18pm
Caesium
When I removed the old ones they literally just fell off, this is another level!
I've ordered BWI bags now. Both my Aerosus ones failed unfortunately and I am not prepared to try again with another two. If it was just one that failed I might accept another but as both are leaking thats a 200% failure rate.
I cant keep taking the car apart. As it is I am now replacing the drop links too as they have been on and off so many times I think they're prematurely worn so I'm changing them. Christian.
Current Cars
2019 BMW X4
or
Post #642786 12th Sep 2022 6:32pm
dingg1
Hopefully the bwi bags will give you a better result Thumbs Up
Post #642787 12th Sep 2022 6:37pm
Gsxr1250dave
I orderd some for my L322 long time ago but never fitted it due to horror stories so sent them back for a full refund, very poor reputation. I only actually need x1front air strut so got original been good as gold ever since. I'm sure a quick Google will provide you with info
Post #642815 12th Sep 2022 11:06pm
Caesium
Still cannot get the airbag off, it's well stuck on there.
Spoke to aerosus and sent them the video, the next step I may have to take is to cut the bag open and strike the underside of the swivel joint. I don't want to damage my struts as they are perfectly serviceable. Christian.
Current Cars
2019 BMW X4
or
Post #642838 13th Sep 2022 9:05am
dingg1
Try clamping the top swivel section in the vice and striking the top of the strut, if you've not already done so Cool
Post #642844 13th Sep 2022 9:57am
dhallworth
Could you use a big puller on the edges of the metal band around the air bag with the centre of it on the top of the strut?
I guess with the hammer you're loosing all the shock through the rubber bag if it's stuck at the top.
Post #642851 13th Sep 2022 11:27am
Caesium
Tried everything and eventually had to cut the bags off.
Now fitted BWI bags and they are faultless. Christian.
Current Cars
2019 BMW X4
or
Post #643573 22nd Sep 2022 9:31am
