![]() | Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
Yeah, I think either front dampers are jiggered, and can’t respond to signal/solenoid stuck, no oil in… or they are fine and the signal is wrong, due to sensor etc. That’s pretty much where the thread started. It’s finding out which, given it’s gonna cost upwards of £1000 to replace front shocks, and some have done that, with no improvement. I know earlier in the thread someone used a diagnostic tool to look at the ECU signals, but guessing we would each need to do similar to prove one way or the other… and I don’t think you can easily rig up something to send “12v” to the shock and see if it’s soft…
I think you're not too far from me, I'd be happy to 'scope the sensor & output signals, can't do much about the damper internals though!
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
If you do sort a meet then let me know and I'll pop over with mine that has working adaptive damping to set a baseline... |
That'd be a good plan! |
Brilliant gents…. That’s a lovely offer from you both. It’s really spoiling the car for me now. If it needs new shocks, it can have them, but I don’t want to do it if it’s not the issue.
Mark, have a chat to Iain and let me know, I can make most times from Saturday afternoon for most of the next week... |
This Saturday p.m. would work for me, can't leave until after 1330 though - maybe move to PM to save cluttering up the thread? |
Nice one. Saturday pm works for me.
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 758 ![]() ![]() |
Really interested to hear your findings chaps!
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2762 ![]() ![]() |
Increasing duty cycle increases the bypass valve open percentage which softens the suspension. 100% duty cycle, ie analogue 12V, fully opens the bypass valve to allow maximum flow through the bypass valve rather than forcing the oil through the main valves. An analogue voltmeter will show an increasing voltage as PWM duty cycle increases whereas an oscilloscope will show that the voltage is 12V switching on and off at the programmed frequency. |
Cheers for that, I was (obviously) guessing which way the bypass would operate as I'm a bit late to this particular party! |
The default bypass valve position is closed. |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1017 ![]() ![]() ![]() |
front bushes - Christian took some photos of his 2011
I don't have any messages on the dash, no Suspension warnings, but would like to figure out how to determine if the car has gone to Hard setting ( as in ECU fault ) , any pointers for me to determine this would be great - thank you |
