![]() | Home > Technical (L322) > Fixing damage |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8706 ![]() ![]() ![]() |
Hi, hope you don't mind a bit of constructive criticism but this bit needs some more work, the line is not straight on the top edge of the swage and the bottom looks to be a bit flat and needs some more filler work to get it back..
longd Member Since: 24 Oct 2020 Location: West Midlands Posts: 95 ![]() ![]() ![]() |
I’d be more |
Just had another look and… it’s still not right !! Well spotted !!’
Thanks so much for your eagle eye , I never bothered eyeing up that swage line as it was not part of the Damaged area … but obviously with the deflection of the panel knocked it out of kilter. Would have shown up immediately in the sun after clear ![]() ![]() I’ve ordered myself 3m pps kit & clear base. Will hold off doing anything till that’s comes , tbh I probably have a weeks worth of vacuuming to do on the inside as I had left tailgate open while sanding ![]() |
It also looks as if the line in blue has got flattened off just above where I have marked in yellow... run a straight edge over the panel, up and down, and I think you will see where it is flatter towards the back.. |
Spot on buddy will get a straight edge on it tomorrow and knock down the high spots and fill in the low spots , my attention was focused on the panel being flat and around shaped correctly around the wheel … everything below that swage I made sure was perfect |
So there was a high spot just above the swage line , tapped it back and filled . line is almost perfect still have a little more filler work to get it 100%
Finally got that profile correct what a ballache that was !!! |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1324 ![]() ![]() ![]() |
Have you got one of them profile gauges that you can take a reference from the other side?
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 923 ![]() ![]() |
If not already, trial fit the rear light unit which should follow the profile of the wing where they meet, if the wings slightly out, it should be obvious |
Getting there though, sort those two areas and it should be spot on... |
Yup am stuck in work for the next couple of days so won’t get a chance to get it sorted , almost there though , I’ve rubbed Down the rest of the panels so I literally just need to fettle the shape for the light and I’m ready to paint ! |
So ended up realising that the weather isn’t going to work with me and the car doesn’t fit in the shed so had to improvise….
