![]() | Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2743 ![]() ![]() |
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 107 ![]() ![]() ![]() |
Hi GraemeS no I don't have that option, I wonder if I need an update or something. It would be handy to have that as well! 2012 TDV8 Autobiography Baltic Blue Previous 2007 BMW M5 E60 |
Its been quite some time since mine was updated but certainly worth trying as Gap have added functonality over time. |
Yep I think you are right about the graphs magnifying the variations and I have probably jumped the gun slightly, just wanted to find something to explain the harshness in the ride without spending fortunes on new shocks like others have done and then had no improvement. My ride has definitely improved after altering the height and zero position although for me its still not perfect, once the new sensors are fitted and calibrated Ill let you know if they make any difference. ![]() Previous 2007 BMW M5 E60 |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 757 ![]() ![]() |
I do notice on mine that if its riding 'ok' on a given day then I drop it to access height and back up to standard it always ends up firmer.
So I have been on to GAP and updated my IID tool, I can now see the ADM values which is great!
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Thank you for clarifying ![]() As I said… my simplistic view… just not a correct view ![]() Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
“Weight on the wheels…” does jacking up the hub to the correct height do enough? For us driveway “mechanics” where we have to work under jacked up cars, this is the only way to get the correct height and access to tighten those bolts. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
I wonder if that is caused by the sensor arms being sticky where bolted to the hub arms? The bendy plastic bit may be flexing causing incorrect readings? Just a thought. Next time I’m under the car I’ll be checking mine as a simple maintenance task. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Did you need to request a specific version? Or just the latest? I didn’t have the ability to see these values (or just missed it) and no with the car just now… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Yep, that should be OK - just as long as the hub to wheelarch measurement is somewhere close. I used to work mobile so I know how 'challenging' doing things like this can be, just make sure you have a second or third safety in case things start to move unexpectedly, an axle stand under the jacking point and another under the front subframe for example, there, but not touching - otherwise it'll be sharing the load. It may be better / safer to put an axle stand under the hub with a relatively soft piece of wood on top for the hub to sink into, and jack up / down on the jacking point, if you start off with the air suspension at access then pull the control fuses, you won't have to fight the compressed air - remember it's only the corner you're working on that needs the hub to be at standard height, the others are immaterial for the purposes of setting the correct pre-load on the bushes. |
It's not just about static values, you need to be looking for anomalies when driving, both from the height sensors and accelerometers, also look at the duty cycles of the dampers - there may be 'hidden' data on CAN having an effect - I haven't a clue what that may be, I'd guess that steering angle and brake activation would / should have some bearing on the duty cycles of the dampers. It'd be interesting to see comparative values from the same stretch of road with your height sensors as-is, with them recalibrated, and with new height sensors if you fit them - the duty cycle outputs would give you a 'composite' measurement, but you'd need to be on a test route where you can do the same speed, the same line on the road and at least one each of a left and right bend. It would, to my mind, confirm or deny that the control system is operating consistently. One thing that I have been wondering about, is how the ADM recognises that the suspension is at calibrated height, given the range of voltages that each sensor can output (anywhere between the dashed lines for a given height from the graphs above), maybe the EAS signals the ADM once the calibrated height is stored? Obviously the 'normal' height reference voltage needs to be known by the ADM so it can detect a change, not just a rate of change and longevity of the change. |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 991 ![]() ![]() ![]() |
are people buying the sensor and the arm - Part No. LR023652
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7991 ![]() ![]() ![]() |
I got the complete arm, genuine part from Duckworths as I’ve read a few things about issues with non genuine sensors.
