Home > Technical (L405) > Rear Noise |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34915 |
you started this same subject thread in august and had a few suggestions....any updates.. ... - .- -.
15th Sep 2022 3:20pm |
SVAuto_Man Member Since: 16 Aug 2022 Location: Coventry, UK Posts: 110 |
It went in for a quick look and other things, hour of a job so now its going in next week for 3 days. Tried fully fueled, half fueled and almost empty and made no difference, always the same. Doesn't seem to do it as it changes gear or going around a corner so I am pretty lost lol |
15th Sep 2022 3:29pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1239 |
Are the dampers moving smoothly without stiction ? I had in my evoque a knocking sound from the rear which didn’t happen all the time, but I could feel thuds on down shifts, thuds on pull away at slow speed. I went through flushing gearbox, re-con diff, haldex full strip/rebuild, rear suspension arms, etc etc …. Only noticed that when jacking it up one time, that the suspension wasn’t extending out smoothly but rather sticking and releasing with jolts. This was the knock I was noticing, the dampers were seizing up.
15th Sep 2022 9:18pm |
Hi ya,
15th Sep 2022 9:37pm |
For me, as I jacked up the car slowly, as the suspension extended to keep the wheel on the ground m, rather than smoothly sliding, it would stick and release jumping about 5mm each time. Each release gave off a thud sound, which is what I was hearing during driving.
16th Sep 2022 9:19am |
Good shout. I am taking the wheels off over the weekend if I get chance so will see if it is sticky etc. |
16th Sep 2022 9:29am |
Tried jacking with wheels off at the weekend. Drivers side seemed a little sticky but not much to be honest |
20th Sep 2022 11:22am |
Hi All,
28th Sep 2022 9:39am |
memzy88 Member Since: 28 Jul 2017 Location: London Posts: 51 |
Great progress. Let us know how you get on 2017 Range Rover SDV6 AB
28th Sep 2022 10:38pm |
Will do. A bit disappointed as I was told a flush and calibration be done today as I have to have car back for the weekend, my tracker says they moved the car about 10 feet at 4.45pm and that’s it for today |
28th Sep 2022 10:40pm |
Dealers are big let down for the brand unfortunately. But the product has no substitute so we all need to bear with them i guess. 2017 Range Rover SDV6 AB
28th Sep 2022 10:55pm |
Yeah exactly. To be honest, they are the best I have delt with. Had many JLR cars, BMWs , Porsches etc but JLR talk to you and listen, the others just read a script and that’s it. I know my issue will take ages to fix, but will be fixed and will be compensated accordingly. That the important service to me. The funny thing is that the car felt like the Ackerman’s theory of a four wheel drive car but on the rear lol |
28th Sep 2022 10:59pm |
Hey guys, car is back in the dealer now for this to be looked at. What do you think, could it be this?
17th Oct 2022 3:22pm |
Yes, it does sound like your problem. The transfer case is where all the differences of rotation between the wheels meet and have to be accommodated by means of friction clutch plates slipping against each other. If the fluid is anything other than in good condition (which it won’t Agee’s tens of thousands of miles) then they can’t slip properly, and end up grabbing against each other until the forces become too much and they release suddenly, the release being the knock and judder your getting. V8 or else ... |
17th Oct 2022 6:35pm |
